#124 started
Re: #124 started
If you mean when you ground the 0.02uF PI cap (same as grounding the return jack tip lug) makes it go quiet, I think that's it then. The jacks are just not providing a solid ground. Removing the anodizing AND using a star washer is best for anything that has to maintain a ground connection.
				larsvictor
Re: #124 started
Marcus,
grounding the PI entrance (connection blue wire to 0.02uF Cap) cancelled the hum, right ?
Grounding lug 2 of the MV potentiometer (or just turning it all the way down) doesn´t have an effect on the hum.
IMO the source of the hum must be between those parts.
ground the tip of the send jack - that should have no effect.
ground the tip of the return jack - if that cancelles the hum the switching contact is bad.
Edit: Martin was faster
Re: #124 started
Quite right Lars, let's not forget about that! See if a patch cable from send to return kills the hum.
				larsvictor
Re: #124 started
Confusing...
Martin asked you to ground at the PI entrance cap (0.02uF)
						Really that one ???but not like when I ground out the PI 0.1uf node which kills it stone dead.
- norburybrook
Re: #124 started
patch cable makes no difference to hum
grounding either node kills the hum completely.
Marcus
Marcus
Re: #124 started
But grounding the MV wiper does not stop the hum?
						- norburybrook
Re: #124 started
no.
M
						M
				larsvictor
Re: #124 started
you mean at the PI caps ? or the jack tips ?grounding either node kills the hum completely.
- norburybrook
Re: #124 started
PI caps, I'm grounding at the 1M Resistor node..is that the correct end?
edit. I think martin wanted me to check the other end.....
grounding the jack end of the 0.02uf has no effect on the hum
				larsvictor
Re: #124 started
Nope. The other terminal of the cap.
						- norburybrook
Re: #124 started
see above
Re: #124 started
Ok, lets get on the same page. Which is the first point where the hum is not stopped?
				larsvictor
Re: #124 started
Ok, then the issue is somewhere in the PI circuit (you mentioned that pulling V3 makes the amp quiet).
Is the NFB reconnected ?
Can you measure the V3 voltages again:
pin 1 and 6
pin 3 and 8,
junction of the 4 resistors,
junction of 24k and 390R/4k7
What happens if you ground the 0,1 PI cap on the 390R terminal ?
pin 1 and 6
pin 3 and 8,
				larsvictor
Re: #124 started
Martin,
I´m afraid at all of the points 1-7...
Marcus grounded the grid (pin7) of the PI.
Lars
Lars
				larsvictor
Re: #124 started
Just to clarify that we´re all looking at the same schematic.
