ayan wrote: I have thought that if the middle cap connected to the top of the bass pot, as opposed to the mid cap directly, then you could lift the whole stack by disconnecting the bass from the middle pot.
Any New Ideas on the LC PAB Circuit?
Re: Any New Ideas on the LC PAB Circuit?
Gil, if the 1.8K is a ground tail on the midpot, then why is there a blue wire soldered there? Look at the pics. Maybe the resistor is just not hooked up....
I understand... nothing appears to make perfect sense, right?dogears wrote:Gil, if the 1.8K is a ground tail on the midpot, then why is there a blue wire soldered there? Look at the pics. Maybe the resistor is just not hooked up....
Gil
