Steel String Singer#002 build from Scratch
timrobertson100
Re: Steel String Singer#002 build from Scratch
Post by timrobertson100 »
What did you do with your mid switch please? I’ve tried various things people have suggested but never been satisfied.
Richard1001
Post by Richard1001 »
timrobertson100 wrote: Tue Dec 17, 2024 7:05 pm What did you do with your mid switch please? I’ve tried various things people have suggested but never been satisfied.
I found that putting a 1uF cap over the 270 ohm resistor in the phase inverter works great and is like other mid/accent switches seen in early amps
Hendrixianer
Post by Hendrixianer »
checked it just now after your question,and i don´t have there any Problems,yeah,it gives a bit of Boost,,but depending on other Filter and Tonestack Settings,you could easily dial in,so where is your Problem with the Mid Switch?
O.k,now i know,what you mean,i tested it before, with Attenuator and Level quiet down,but without Attenuator and Level up it is very Harsch,so i have to work on it,so my first Impression was right on it :lol:
DIY Amps: Marshall JTM45,Orange Grafik II 50W,Some 18W Marshalls,Dumble ODS 50W,Hiwatt DR103,Madamp G3 Blues,Dumble Steel String Singer, Fender Standalone Reverb 6G15,a few Hundred Pedals,like Uni-Vibe,etc,etc... :D
Hendrixianer
Richard1001 wrote: Tue Dec 17, 2024 7:19 pm
Thank´s,found your Thread and the updated Layout :D
https://ampgarage.com/forum/viewtopic.p ... caf99fa8d8
dorrisant
Post by dorrisant »
Hendrixianer wrote: Sun Dec 15, 2024 1:50 pm It seems,Nobody take care of it,in all the Steel String Singer clones :roll:
Martin's way of doing it gives you about 170v potential... So not "nobody". :lol:
Nice build. It should bring joy. :)
Hendrixianer
dorrisant wrote: Wed Dec 18, 2024 8:13 pm
Thanks,
But Martin didn´t give me a Potential of 170V,I don´t mean the Cathode Follower after the Pi,I mean the CF after the Filter Switches,there i have cathode Voltages over 220V !
played just 2 hours,checked all Switch Positions,yeah,Mega Fun to play this Amp :D
The mixer stage CF's run at 206V Vh-k per my simulation (440V B+1). Data sheets show a maximum of either 180 or 200V depending upon the brand. It's a good idea to elevate the heater string to be safe.
Hendrixianer
And here is the modifyed Layout which now corresponds my to Build:
Attention: Protection Diodes on OT are R3000 Types,and not 1N4007 !
Nice, thanks for posting that. I suggest that your modified drawing should be clearly identified as such, and it should list the differences from Ryan's layout.
Hendrixianer
martin manning wrote: Wed Dec 25, 2024 12:32 pm Nice, thanks for posting that. I suggest that your modified drawing should be clearly identified as such, and it should list the differences from Ryan's layout.
Yes,Sorry,Done !!!
Hendrixianer
Hendrixianer wrote: Wed Dec 25, 2024 1:03 pm
Yes,Sorry,Done !!!
And much Thanks to you and R. Colgan,for your hard Work and posting it in Net,so i could build this Amazing Amp :D
No problem, and thank you!
Hendrixianer
Finished the Headshell Today :D
captaincoconut
Post by captaincoconut »
Sehr schön!
timrobertson100
Perhaps a daft question… you don’t use 100R balancing resistors when elevating the heaters?
