HRM in a Tweedle Dee?
professormudd
Re: HRM in a Tweedle Dee?
Post by professormudd »
fred.violleau wrote: Tue Feb 15, 2022 3:05 am I tested it, I remembered I had an old HRM board sitting somewhere from a build I rescued. So I plugged it into the normal channel and it worked fine. There is a little signal loss compared to the bright channel but nothing to worry about.
I would like that settings to shape the sound when in cascade mode.
It would probably work better if this HRM board was coming later in the preamp circuit ala Marshall, after the two cascading gain stage. But then you are trying to reinvent a Marshall or a fender or a little dumble ;)
All this too say, have fun and try it. If you use often the same instrument with an amp, might as well tune the amp for the guitar! A cool way would be to have a relay engaging the HRM board only when cascading!
Here is a pic of my ugly setup:
Fred
Yeah I am going to try it in a few places and see how it goes, I guess. I was mostly interested in exploring other ways to modify this little amp, along with exploring other ways to employ these little hrm boards I have.
Thanks for being a willing participant in this silly idea.
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
