to HRM or not
Normster
Re: to HRM or not
Post by Normster »
Pete wrote:I think for rock you may want to explore HRM but it will be necessary to use together with the PAB on. Think of the M in HRM. just my $0.02.
Monkey? :lol: (j/k)
As for the HRM not having quite the gain of the '80s style, I guess that depends on whether you've done a "pure" implementation. Scott will most likely bash me for saying this, but if you max out the trimmer and use a linear OD gain pot you can turn the HRM into a gain monster.
heisthl
Re: to HRM or not
Post by heisthl »
I was all set to disagree on the HRM being better for rock but then I realized that if your preference would be a Marshall sound the HRM is better. Personally for a rock gig using a HRM I'd miss the non-HRM.
www.RedPlateAmps.com
TimS
Re: to HRM or not
Post by TimS »
Besides the added tone stack, how different is an HRM amp from a non-HRM circuitwise? If I wanted to experiment with adding the post OD tonestack to a non-HRM amp, would I be looking at a few component changes or a complete overhaul of the amp?
heisthl
Re: to HRM or not
Post by heisthl »
Look in the files section at the Bassman and SuperReverb posts, ignore the reverb and/or loop parts and compare the differences. You could do the HRM layout but put a non-HRM on it rather than making the add on board like Dumble did.
llemtt
Re: to HRM or not
Post by llemtt »
heisthl wrote:any idea what the lower right resistor is doing? looks to be connected to the mid pot with a value of 1k8
Pre skyliner TS.
Amp is sn 118 (early 80's), then HAD rebuilded it to newer specs. HRM is retrofitted, new power supply (you can still see and old cap chassis hole), and V2 circuit it's changed (different green wires joined).
Teo
kleinm
Re: to HRM or not
Post by kleinm »
dogears wrote:I guess this means that the pic on the site is authentic. I have had it for a while. Funk is right btw. This is way different. Let's see what astute eyes point out..... ;)
I see a very warm, cuddley PI long-pair tail (different from current schems, similar to a certain '60s amp)...and a happy NFB and Presence setup (again, different than current schems and similar to a certain '60s amp). One of the PI plates is at 91k, so I assume the other one is at 100k.
Cool stuff!
67:1
Funkalicousgroove
Re: to HRM or not
Post by Funkalicousgroove »
Try 110K.
chris_sanford
Re: to HRM or not
Post by chris_sanford »
Pre skyliner TS.
Teo
Don't think so. Tail resistor on the mid pot looks more like the Bluesmaster TS (think Marshall style).
chris
TimS
Re: to HRM or not
Post by TimS »
kleinm wrote:I see a very warm, cuddley PI long-pair tail (different from current schems, similar to a certain '60s amp)...and a happy NFB and Presence setup (again, different than current schems and similar to a certain '60s amp).
Been watching Bob Ross reruns on PBS again? :lol:
TimS
Re: to HRM or not
Post by TimS »
chris_sanford wrote:Don't think so. Tail resistor on the mid pot looks more like the Bluesmaster TS (think Marshall style).
I hope I'm not stepping on anyone's toes or violating some unwritten rule by asking this, but what exactly is the Bluesmaster? I keep seeing references to it but it seems to be somewhat of a taboo subject, or at least one that's kept very quiet.
If it's not cool to talk about here, let me know and I'll delete this post, but otherwise would someone mind filling me in? I'm not asking for circuit details (I'd love to know them if anybody would like to share, but they seem to be a closely guarded secret); I'm just curious about the history of the amp - when it was made, who used it, etc.
Thanks.
heisthl
Re: to HRM or not
Post by heisthl »
http://www.raw-sewage.net/jtm45ri_mods.html - scroll to the bottom of the page. There are several versions of the same basic schematic. I don't see anything with a mid pot tail resistor or .02 caps to the output grids.
heisthl
Re: to HRM or not
Post by heisthl »
Ooops that link is for a BluesBreaker not a BluesMaster
chris_sanford
Re: to HRM or not
Thanks.
Hi Tim,
From the information I've been able to piece together, the Bluesmaster uses a traditional Marshall-style tone stack and PI values, but is otherwise similar to the HRM schematic found on this site. I have no idea when this circuit appeared, or who might have used it. Clearly though, the pic posted in this thread looks like one of these beasties, although the flipped overdrive stage input wires are a new twist. :)
chris
kleinm
Re: to HRM or not
Post by kleinm »
chris_sanford wrote: Don't think so. Tail resistor on the mid pot looks more like the Bluesmaster TS (think Marshall style).
chris
Correct me if I'm wrong, but I don't ever recall seeing a Marshall tonestack with a fixed resistor to ground off the Midrange control. I'll look at my Doyle book again.
67:1
kleinm
Re: to HRM or not
Post by kleinm »
BTW - you can see in the picture that the Midrange pot is an Alpha 250k. Again, this isn't a Marshall-style midrange value that I'm aware of.
It appears its a Skyliner midrange value, and the 1k8 (assuming that's correct) is just connecting the resistor to ground, and not having much effect on the frequency knee or taper. Just speculation, though.
67:1
