Troubleshooting Help, New 183, Low Voltages
ToneMerc
Re: Troubleshooting Help, New 183, Low Voltages
Post by ToneMerc »
Structo wrote:Not sure I understand why you didn't ground the CT of the heater winding?
Or use an artificial CT with a couple 100R resistors to ground.
Damn these amps get very crowded around the power tubes.
Tom, he did use 100R for the artificial taps, see V4 & V5.
TM
Ahh, now I see 'em. :D
jlatrace
Post by jlatrace »
Okay, I found MY problem (truly was my problem, not the amp). PT is okay, wiring is okay, voltages are okay.
What was "my problem" you might ask?.....Taking voltage measurements while the amp is still hooked up to my light bulb limiter! Remove the limiter and plug the amp in to the 120 volt wall sockett, problem solved.
What a ridiculous mistake. I am very sorry I waisted all your time. I will add this "mistake" to my checklist. ("Remove light bulb limiter, plug amp in, then take voltage measurements).
CHIP
Post by CHIP »
We all learn from mistakes.
Nice build, tell us how she sounds.
JazzGuitarGimp
Post by JazzGuitarGimp »
Always nice to see the solution.... congrats! Let us know what you think of the tone....
bluesfendermanblues
Post by bluesfendermanblues »
Congratulations with solving the issue.
ToneMerc
Post by ToneMerc »
jlatrace wrote: What a ridiculous mistake. I am very sorry I waisted all your time. I will add this "mistake" to my checklist. ("Remove light bulb limiter, plug amp in, then take voltage measurements).
Sometimes they make the best learning experiences, view it as knowledge gained, not time wasted. I'm glad you stuck with it.
Enjoy
Mike
jlatrace
Post by jlatrace »
Thanks. Funny thing was I realized my mistake only after:
1) installing new PT
2) cutting newly installed leads on new PT
3) deciding the rectifier board was bad, cutting the leads and taking it out to inspect
3) retaking voltage of old PT to find it measured perfectly
4) tracing the problem ( by re- hooking up the new PT one lead at a time) to the AC coming into the amp.
5) saying !@&$!@& many times.
6) taking the light bulb limiter off and plugging the amp into the 120v wall socket, problem solved.
I need to put the old PT back in and fire it up. I'll report back on the tone.
Les
Bob-I
Post by Bob-I »
jlatrace wrote:Okay, I found MY problem (truly was my problem, not the amp). PT is okay, wiring is okay, voltages are okay.
Been there :oops: I musta spent 5-6 hours troubleshooting. In my case, unloaded I was getting voltages close to what I expected, but as soon as I flipped the standby :?
Glad you found it.
