*New Build Thread* 2nd Gen Hybrid 50w footswitchable FET
boldaslove6789
Re: *New Build Thread* 2nd Gen Hybrid 50w footswitchable FET
Post by boldaslove6789 »
martin manning wrote:
boldaslove6789 wrote:Usually most RG-400 cable (can be found at Air Craft Surplus stores) will usually be around 75ohm per foot, so you have to do the math and figure out how much highs you'll want to roll off by calculating how many Feet of RG-400 cable will equal the amount of your simulation capacitor.
RG400 cable is 50 ohm impedance regardless of its length, but that is not at all important for audio frequencies. It's capacitance is spec'd at 29.4 pF/ft.
Yes you're right. Sorry late night misinterpretation.
(RG-400 is Quite a Loss'y cable.)
Dr d
Post by Dr d »
Greg, thank you very much for your help. I will try out your suggestions!
Guitarman18
Post by Guitarman18 »
Good to hear that your 2nd Gen has come to life Dr d! This is yet another amp on my 'must do' list.
On the RG400 front, if any euro guys know of a good supplier I'd love to know. This is the one ingredient missing from my #102 amp.
Paul.
'Beauty is in the ear of the beholder'
If I were you I wound just look online at UK shops and look at their bulk cable data.
Look for the pf/ ft rating, although it may be given in pf/ meter.
Something around 30pf/ ft would be equivalent.
BTW, I don't use RG400 on my amp.
I use short patch cables like you use on a pedal board to go from the
Dumbleator to amp.
Then I have fairly long cables to and from the pedal board back to the D'lator.
I believe I used Mogami W2524 for that.
It has a capacitance of 39.7pF/ Ft
amplifiednation
Post by amplifiednation »
Here's a clip of my amp through the Dumbleator, reverb and tape delay...
first half volume is turned down on the guitar, second half volume turned up, nice grumbley spanky tone from this Asher T
http://www.youtube.com/watch?v=s19rTsy4 ... e=youtu.be
Amplified Nation
www.amplifiednation.com
@ampnation
