Aaron wrote: ↑Mon Feb 17, 2020 9:02 am
Thanks for the info Tony. I wasn’t too far off with my guesstimates considering I only had the fuzzy photo copies and the preamp schematic.
The only missing piece of the puzzle was the mixing circuit. Might have to dig my build out and see if it makes much of a difference.
I really like the preamp in this amp. Crank that preamp volume to 10! I bought some 6U8A valves ages ago with the intention of doing a similar preamp with one valve.
You wouldn’t happen to have the resistor value sheet for the preamp?
Thanks,
Aaron
Aaron, I just went through my files and compared to Tony's and there are these additional 3 missing from his posts, one of which is the preamp for resistors.
I spent a fair bit of time with those pdfs and maybe my schematic will save you some time. I have done amendments as per Bill's schematic.
Questions pending:
1) bias network on the PI, are my 2x10K, 2x30k correct? Where should the 47K go?
2) where should the extra 1M go on the tremolo
3) on the pentode is the .1uF going to cathode or ground on the original
4) on the supply there are 6x470k, so the 2x47uF (350V) are indeed stacked. Does my current schematic look good? Any ideas on the 2x 40K (5W) and how to go about the PI driver (which doesn’t have a dropping resistor listed and also is missing a cap supply)
5) the lnfb on the reverb, is the 10k inside or outside? I’ve seen amps taking both approaches
6) The reverb entrance, Bill's schematic has it as per my green line, I used the standard approachm which for me makes more sense. Which is correct?
7) I think the 220K on the reverb return is as per AB763 (mixing resistor), and not after the decoupling as per Bill's schematic.
EDIT: Updated schematic further down the thread
