I don't know the primary impedance,I'll find out.And yes it is the stock 100W Carvin OT.Thanks for the tips!Structo wrote:Gary,garysanders wrote:Cool,not trying to jack that thread but I am having the same problem.
I made an error on the last post.I have the 4.7/1uf/390 now and its way to dirty.At the high end of the pot it makes a quiet but very high pitched whistle.Like positive FB.I think Bob has explained this to me but it was some time ago.
Try switching the wire from the resistor to the 8 ohm tap or 16 ohm tap to see what that gives you.
If that doesn't help, try a 6K2 resistor or a 8K2 one.
I can't remember what OT you are running, is it the stock Carvin OT?
And that is a 100 watt OT right?
Did you ever figure out what the primary impedance of that OT is?
edit:(I'm also fooling with a pot instead of the 4.7k resistor.I have it sounding good on the 16R tap.I'll measure the pot and put a resistor in its place.(I saw that in another thread))
