Comments?
ampdan
Comments?
Post by ampdan »
So..this just showed up on my bench.
Converted Popular?
pottedplant
Re: Comments?
Post by pottedplant »
That's so unbelievably cool. I see there are F&T's in there, nice to know he didn't mind them!
award70
Re: Comments?
Post by award70 »
Does it have a name?
Colossal
Re: Comments?
Post by Colossal »
award70 wrote: Mon Feb 17, 2025 12:45 am Does it have a name?
Looks like a Marshall 18W 1974 circuit. Sweet amp!
ampdan
Re: Comments?
Post by ampdan »
Would Dumble have converted a Marshall Popular to an 18 watt? Did he ever sign amps? IDK.
That's why I posted it. The cabinet is interesting also. I'll post pics.
alnight
Re: Comments?
Post by alnight »
That's really interesting. I don't know enough to have much of an opinion other than, I think it's neat! Thanks for sharing.
dbharris
Re: Comments?
Post by dbharris »
Very cool, thanks for sharing! It would be great if you could post a picture of the tube socket wiring.
-Dan
Colossal
Re: Comments?
Post by Colossal »
Interesting to note that the Normal channel coupling cap was increased to 0.022uF from the stock 0.0047uF and the cathode bypass to 250uF from the stock 50uF (kind of like the Normal channel of a Plexi). Tone control on the first stage, then second stage with second order output to its Volume and Tone controls. Standard Marshall 18W PI with added Cut control. 47p added across the PI plates. Looks like the EZ81 was removed and replaced with a solid state rectifier and 300R screen resistor. All tubes moved down one position and the first socket covered. Polypropylene cap (IC MPW) added on the PI non-inverting side.
ampdan
Re: Comments?
Post by ampdan »
I'm fairly certain this is a converted Marshall Popular. The cabinet is interesting also...
Colossal
Re: Comments?
Post by Colossal »
ampdan wrote: Mon Feb 17, 2025 2:20 pm I'm fairly certain this is a converted Marshall Popular
I would agree as the layout for the SS rectifier is the same as the Popular.
ubikwidus
Re: Comments?
Post by ubikwidus »
ampdan wrote: Mon Feb 17, 2025 2:22 am Would Dumble have converted a Marshall Popular to an 18 watt? Did he ever sign amps? IDK.
There are Dumble amps out there with his signature and handwriting on them. One of my Princetons that he built has his name on it. Very cool amp you have there!
ampdan
Re: Comments?
Post by ampdan »
The problem is, all of the components used are 2000's era. So, unless there was time travel involved....
I also have my doubts about the originality of the cabinet itself.
ubikwidus
Re: Comments?
Post by ubikwidus »
ampdan wrote: Tue Feb 18, 2025 2:52 pm The problem is, all of the components used are 2000's era. So, unless there was time travel involved....
You could try contacting the dudes at Dumble.com/preservation society. They have a ledger but it isn't complete (missing stuff from early on and in the more recent era)..... You can try though. This amp could have had more than one tech and that could explain the age/parts discrepency.
