BM OD low level
lovetone
BM OD low level
Post by lovetone »
Sometime ago I built a Blues Master, I am very pleased with the overall tone including the OD which I really enjoy.
The issue I have always had is that the OD level is much lower than the Clean. Its never been a problem before but I would like to us the amp foe gigs and just can't get enough OD level in a bad situation.
I'm wondering if anyone else has this problem? I have checked my build to the schematic and can't find any problems.
Cheers
jazzbass
Re: BM OD low level
Post by jazzbass »
Hi Lovetone,
can you please send photos of your amplifier, possibly in high resolution.
Franco
franco mezzalira
Re: BM OD low level
lovetone wrote: Fri Jul 21, 2023 8:09 am Sometime ago I built a Blues Master, I am very pleased with the overall tone including the OD which I really enjoy.
Since the OD is working and sounds good, I would suspect something is not right between the OD 2nd stage output and the PI input, possibly an incorrect part value, bad solder connection, or wiring error. I would send some signal through the amp, and with the OD master all he way up, look for a drop in signal level starting at the OD output coupling cap. You will of course expect a large signal loss through the HRM. You could do this with a DMM if you don't have a scope.
Guitarman18
Re: BM OD low level
Post by Guitarman18 »
It’s worth remembering that the OD of a BM is traditionally used in conjunction with PAB. If OD+PAD is lacking in volume, then yes, you have an issue, but it’s normal for a BM OD without PAB engaged to be lower volume.
I hope that helps.
'Beauty is in the ear of the beholder'
lovetone
Re: BM OD low level
Post by lovetone »
Cheers
Okay that may be the issue i'll check that out.
Re: BM OD low level
Have you tried adjusting the OD entrance trimmer?
