Need help designing a face/back plate (Twin > DClone)
Tonegeek
Re: Need help designing a face/back plate (Twin > DClone)
Post by Tonegeek »
Kinkos made one for me on vinyl and then laminated it on both sides with clear plastic. The employee who did it said they could laminate one side or both so I did both and then used 3M spray to put it directly on the chassis. It is holding up well and after a year of constantly removing the chassis for tweaking it is only delaminating just a bit on the corners. The peel and stick works well too. You might ask if they can laminate one side and have a peel on the other, then you get the best of both worlds - durability and easy attachment.
Pitcher Amplification
http://pitcheramps.com
heisthl
Post by heisthl »
Kinko's sign vinyl is designed to withstand the outdoor elements for 5 years so lamination is probably not needed - doesn't the laminate make the panel too shiny?
When you have Kinko's do one always ask them to fill up the sheet with duplicates so you have at least one spare if you srew up the mounting. Its best to use double sided tape to do a test mount (you can sight through the chassis holes to align and then exacto out a few holes before you peel and stick, so you get it on straight. Wipe the panel down with alcohol or mineral spirits before the final mounting and just exacto out the rest of the holes.
www.RedPlateAmps.com
Tonegeek
Post by Tonegeek »
heisthl wrote:Kinko's sign vinyl is designed to withstand the outdoor elements for 5 years so lamination is probably not needed - doesn't the laminate make the panel too shiny?
It is very shiny. Looks like patent leather :D On my HRM amp I felt I needed the laminate because I was afraid just the vinyl would pick up some of the flaws in the actual chassis. Also on the back I drilled a couple of holes that I needed to cover up :oops: and the laminate hides a multitude of sins... If I ever get this Twin going, I may not need the laminate because the amp already has an actual separate faceplate that I can prep and apply the vinyl directly to. Sure would be nice to not have to deal with the adhesive spray.
heisthl
Post by heisthl »
Use JB Stick weld to plug any holes and sand the chassis panel smooth and put the vinyl right on the chassis. I never use the separate faceplates because I don't like the added thickness.
skyyamps
Post by skyyamps »
great post! im building an amp right now and am about ti run into this problem. how much did KINKOS charge because who wants to spend $50+ on customized plates?
-skyy amps
samrock55
Post by samrock55 »
Did anyone build this Dclone with this reverb? And how great does it sound? Is it worth the building and effort? Where exactly was this amp derived from? Does this have a power supply schematic? Thank you Sam
talbany
Post by talbany »
samrock55 wrote: Sat Apr 16, 2022 10:51 pm Did anyone build this Dclone with this reverb? And how great does it sound? Is it worth the building and effort? Where exactly was this amp derived from? Does this have a power supply schematic? Thank you Sam
https://tubeamparchive.com/viewtopic.php?t=2976&start=0
AFAIK Henry used the same schematic/Preamp (2 tube Reverb) for his Twin conversions.
Never tried it and it doesn't interest me at all.. :D
samrock55
Post by samrock55 »
Tony whats the best reverb Dumble Layout you have heard?
