Death By Conversion II: Adventures in HRM Land
ayan
Post by ayan »
Background
Man is one of the few animals that stumbles over the same rock twice... at least I am. Having tried and abandoned HRMs 8 years ago, I decided to give it another shot again in my last build. The amp started off as a full blown BM; first I changed the BM boost to something else; then I changed the preamp to Skyliner, with the convetional PAB; then I lost the BM PI. I struggled with the HRM for a few days and I finally jumped ship for the third time in eight years. But, rather that only venting my frustration, I will also try to tell you about some of the things I found along the way that you may find of interest and use.
HRM Struggles
As you may have read in the other thread, my biggest problem has always been finding a smooth sound out of an HRM. I'll qualify my findings by disclaiming that my speakers of choice are EVM 12Ls, and that I also play a 2x12 oval-ported cabinets loaded with some kind of discontinued Eminences that sound kind of like a Celestion 90W (Boogie) speaker, except I bought them at their blow price of $24 (I think) each. Those speakers have worked well for me for quite some time.
After struggling a lot with the HRM, I was able to arrive (again) at some clonclusions. First and foremost, to get something close to that "RF" type of sound that Scott has come to master, I did have to turn the gain up quite high [Preamp volume at about 1 o'clock; OD trimmer at 25K to ground; OD gain at 1-2 o'clock] and use the amp in PAB mode. Although I realize I didn't spend enought time to adjust my approach to fit this amp, I was able to see the sound has some good qualities to it. However, it is definitely not user friendly. The amp does scream nicely on the upper register notes, but it will buzz out just as easily on the lower register notes. Double stops are somewhat amusical and have a tendency to develop that intermodulation noise (like an engine reving up) that folks are currently discussing in another thread.
My biggest gripes are: (1) When that sound was dialed in, it would only work with the bridge or bridge + neck (w/neck volume rolled off) pickups on my 335 only, the rhythm pickup didn't sound so good. Worse yet, my Tele sounded ear piering bright through the amp... and forget about the Strat, it sounded simply horrible (Strats have always been the hardest guitars to dial in with Dumble amps, in my -- and many others' -- opinion). (2) If I should dial the gain down, for a cleaner type of OD sound, the tone would become dark and the pick attack would be masked in a bad way. Brightening the amp via HRM would fix that, but then turning the gain up would make the higher-gain tone piercing bright and harsh. (3) As it is common knowledge, the sound of the HRM without the PAB on is just not happening at all. (4) I know other folks have brough this point up as well: the OD sound, dialed in, has no real ressemblence to the character of the clean channel's tone.
HRM Experimentations
I gave the concept of HRM the benefit of the doubt, wondering whether I might have a bum amp to begin with, in which case the poor HRM should not be blamed for my less than encouraging results. So I disconnected the ground on my HRM board and basically did an A/B test: amp w/HRM VS amp with HRM board not grounded, and hanging a 100K resistor to ground at the input of the OD master (to simulate the non HRM topology). Without the HRM board, the amp was very clean and sustainy sounding, with a nice tendency to hang on to notes and start feeding back. Grounding the HRM would obviously result in volume loss, so I would up the master and listen. The tone would lose its vocal quality, it seemed as though the fundamentals were attenuated, and feedback was gone as well. I upped the gain to restore some of the sustain and the sound was workable, but I then disconnected the ground of the HRM, etc., and the tone now was like an "ebow." The amp cwouldlatch on to just about any note and sing away, the difference was night and day.
I forgot about chasing the "RF tone" and decided to dial the HRM controls so that the amp would sound as lose as possible to the non HRM case. Obviously I ended up with the midrange control cranked up and the bass and treble controls barely cracked open. The sound was pretty good that way... But this is the kicker: I would play the amp like that for a while and there were some "burrs" on the notes, like a little "crunch" [think about trying to get a pristine clean sound outof a boost type of pedal, where there will always be some stuff going on that cannot be dialed out] that was always there. Of course, lifting the ground on the HRM would get rid of that and make the sound the way it "should" be.
Conclusions
The only valid conclusion here is that I really don't get along with the HRM... But, from a a more technical point of view, something is introduced by the HRM that is unplesant to my ears. A fellow reported in a post yesterday that when he scoped an HRM amp the observed some weird behavior at V2B. I am not sure what it is, I am not sure if it's the phase shift introduced by the additional circuitry being driven but a hgih impedance source or what. I know the HRM gets more palatable to me with higher volume but even then, it's not worth the aggravation.
I am not suggesting the HRM amps sound bad, nor that an HRM amp can't sound smooth. But I would be interested to find out whether there exists any amp that will sound "smoother" and with more sustain with the HRM stuff added to it.
Epilog
By the end of the day yestersday, I was splitting hairs between my conversion-in-progress amp and my others. So the first thing I did is to replace the HRM board with a "conversion board." The amp sounded obviously more like I liked, but it was still not 100% right. I added the snubbers at V2's socket and things got a little better. But it still wasn't 100% right; at higher gain settings the amp seemed to be much brighter (in lead more) than at lower gain settings, something which my other amps don't really do. I fiddled with that for a while and then replaced the HRM-style pre OD network with the more conventional one for non HRM amps, and that made a hige difference. Something about having a higher impedance hanging off V1B, in addition to the obvious change in frequency shaping... Miller's capacitance perhaps?
The amps were sounding really close by then, although I never changed V2's resistors, but there was still something not quite 100%. While in OD mode, PAB VS not PAB had a difference in the feel of the highs that I was not familiar with. OK, I went for broke and added the feedback netwrok around V1B. That seemed to make the amp respond like the others... and it was late, so I have up on it for the day. In the conversion process, I left the 250KA drive pot but changed the coupling cap from .0022uF (HRM) to .005uF. The board I hung at the end of the overdrive has a .005uF coupling cap coming out of V2B, followed by a 68K resistor and a 200K trimmer to ground set about 55K to ground (this simulates the common 150 K or 180K + 100KL OD master -- set just past halfway up -- arrangement in non HRM amps), plus my trusty old 250K + .001uF cap to ground from top of the trimmer to ground. I will post pictues of "Frankenstein" later. :)
Bottom line, if you love your HRM, great! If you're struggling with yours and share any of the gripes I enumerated above, you may want to spend a couple of hours doind similar tests to the ones I did and who knows, you too might want to convert your amp.
Gil
mat
Re: Death By Conversion II: Adventures in HRM Land
Post by mat »
Thanks Gil for a very informative post. I surely will try nonHRM pre OD network and the feedbck network to V1B + the snubbers and see where that gets me 8)
mat
Tonegeek
Post by Tonegeek »
Clips please! Thanks for taking time to elaborate. I for one am very grateful.
whit
Pitcher Amplification
http://pitcheramps.com
dogears
Post by dogears »
In order to save face here (LOL), I have to go on record saying that in my HRM amp (which has far different topography than what Gil had), I much prefer the HRM, as has almost everyone who has tried it. I find for my hyper fusion style, the string to string seperation and articulation is far superior for playing complex harmonies. It also cleans up 100 fold better than non HRM with the volume. I do use very good NOS tubes. That definately helped.
They do work. I also agree that the neck pickup is not so good with lots of OD. Good thing I use the bridge.
If you want a Jing Chi or Blue Moon era "Fordish" type tone, the HRM is it.
ayan
Post by ayan »
mat wrote:Thanks Gil for a very informative post. I surely will try nonHRM pre OD network and the feedbck network to V1B + the snubbers and see where that gets me 8)
I would first lose (temporarily) the HRM board and see if that is a step in the right direction for you. If not, there probably wouldn't be much point in going in that non-HRM direction.
Tonegeek wrote:Clips please! Thanks for taking time to elaborate. I for one am very grateful.
whit
Hmmm... all I have ever posted over the last 9 years have been from band gigs or demos, etc. What I have is many years old, as the last studio thing I did was using a nylon string for a friend's record. Unfortunately, I have no means to record at home other than a hand held cassette thingie. I can, however, bring an amp to any hang there may be at the NAMM show, if that works for anyone.
dogears wrote:In order to save face here (LOL), I have to go on record saying that in my HRM amp (which has far different topography than what Gil had), I much prefer the HRM, as has almost everyone who has tried it.
Scott, you don't have to save face, you get a terrific sound through your amps. To me, first of all, it may or may not be possible to get that happening, but then there are all the other gripes I described. Our topologies are different only if you're specifically referring to how you deviate from what's in the actual amps, e.g., your "special" boost, which totally works for you but would further take me away from the neck pickup or a Strat, for example.
The HRM totally works and there are people who prefer that, as there are those who prefer a good Marshall for that other kind of sound. My challenge is to find an amp that sounds, as I said, "smoother" by tacking on the HRM board at the end of the overdrive chain, as smoothness is what I look for in these amps.
Gil
dogears
Post by dogears »
Smooth is good.... I love smooth. I think it sounds really smooth. Although a different flavor of smooth. I have both voices in the Glaswerks and the 80s voice is totally comparable with the other builders amps I have played.
One thing, I do not like the sound of this setup with anything but my G1265 speakers. I have a bunch of Lead 80s. Not nearly as nice as the G1265. They seem to really smooth things.
As for topography, in addition to the boost, I have those other things too.... ; Plus the built in Dumbleator which I have also tweaked as part of the big picture.
Look forward to seeing you at NAMM!
ayan
Post by ayan »
dogears wrote:Smooth is good.... I love smooth. I think it sounds really smooth. Although a different flavor of smooth. I have both voices in the Glaswerks and the 80s voice is totally comparable with the other builders amps I have played.
Well, you're not the first person to mention the 65s as a "must" for these amps, I will probably never know. [ Maybe that's why RF spent years trying to get the right speakers with that rig? ]
Absolutely, looking forward to NAMM!!
Gil
dogears
Post by dogears »
I forgot to mention, I abhor the tone with my EVMs!!!! :evil:
Gil
Normster
Post by Normster »
I'm pretty sure the ultimate hang will be at Billy's studio. :wink:
Fischerman
Post by Fischerman »
Good info Gil. I might try this with mine next chance I get.
...and then replaced the HRM-style pre OD network with the more conventional one for non HRM amps, and that made a hige difference. Something about having a higher impedance hanging off V1B, in addition to the obvious change in frequency shaping... Miller's capacitance perhaps?
Did you try a lower impedance off of V1B with the HRM? To this point I've always tried to maintain that load when messing with the pre-OD network.
mat
Post by mat »
I'm gettin rid of the hrm boar too (temporarily). You mentioned the 250k + .001 to ground from top of the trimmer. How are they wired ?
I will make an conversion board also, thanks for the inspiration :D
dogears, I think there still might be something very basic things wrong on my build, but as I haven't nailed it (them), I have to do something to change the circuit (sound). I've learned that I like more of the nonHRM sounds. You are not about to lose face quite contrary 8) I value Your help (and those dogears :D ) very high during the 2+ years I've been here :!:
mat
ayan
Post by ayan »
mat wrote:You mentioned the 250k + .001 to ground from top of the trimmer. How are they wired ?
So form that node -- input of "my" trimmer in the concversion board, which is in place of the 100KL Master OD Volume pot in the real thing -- you connect a 250K trimnmer wired as a variable resistor, followed by a 1,000pF cap to ground. I forget which one I put first, cap or pot, but it doesn't matter either way. This is identical to a common tone control found in 99% of the guitars out there. :)
Gil
anyone
Post by anyone »
ayan wrote: I can, however, bring an amp to any hang there may be at the NAMM show, if that works for anyone.
Gil
I'd love to hear one (or a few...) of your amps at NAMM. Could you give an update about where you end up hangin'?
Thanks,
Chris
ayan
Post by ayan »
Gil
Thanks,
Chris
Well, I can pack an amp in my car and bring it to Anaheim. If anyone will be having a tone party at one of their suites, I could take the amp there. Conversly, if there will be a hang in L.A., I can take an amp there.
Not sure about the logistics of any of this, I know I will not be hosting anything myself, but will gladly participate in someone else's event -- provided I am invited. :)
Gil
dogears
Post by dogears »
Brownnote Suite!
