A few ?'s re- my Wonderland build
I have finished my Wonderland build & have built it a very nice Maple head cab which awaits its final tweaking. The amp fired right up with no real issues, after swapping the OT primaries, it didnt squeal but rapid speaker oscillation occurred, swapping the OT primaries corrected it. The amp sounds fantastic! Very nice tone at all volumes & all the controls work as they should. Here are the questions / issues.
The mid & deep switches seem to have a minimal affect on tone & volume There is a slight volume & mid boost (very slight) but nothing like on the ODS builds ive done. Is this normal or does this sound like something is wrong? The bright switch works as it should.
The reverb sounds great and is very lush but does not seem to go far enough. As it is I can turn both knobs all the way up & it is very "useable" & not over the top. I have tried several tanks & all seem to give the same performance. I have a 5751 in v3. Will an 12AT7 add anything? AX7? Some other mod or area to look at?
Other than these relatively minor issues Im very pleased with how this has turned out, advice & comments are appreciated. . Joe
Resistors not Transistors !
- norburybrook
Re: A few ?'s re- my Wonderland build
the mid and deep are quite subtle yes. I've never needed to turn the reverb controls past midway on my amp , I think I've got a 12 AT7 I'd have to check.
perhaps if you can be bothered look at my build thread, I imagine the valve choices will be near the end.
Marcus
Marcus
Using an AT7 helped a little but not much. I want to get a good bit more out of it before I call it done. Does anyone think changing the 100k send & return pots to 250k or beyond will increase the signal to the reverb tank? I changed the 220k grid resistor on v2 to 470k & again it may have been a little help, but im looking for a pretty good increase. . . Joe
- norburybrook
Joe,
the reverb circuit in this amp does kill a lot of general gain. Did you keep the 1M-68k voltage divider as per the layout? I changed that on my build as I felt it just killed the gain too much even on a 100w amp. I can't remember what I changed it to, check my build thread.
Also on an amp less than 100w I wouldn't bother with the master volume, it's really the global fx return volume so should be up full anyway.
Just thinking aloud here so hope any of that helps.
Marcus
Marcus
I do. A simple "test" would be to add a 100k to 470k range resistor from the reverb send pot to ground (from the ground side). A Fender dwell pot would typically be 1M there.Does anyone think changing the 100k send & return pots to 250k or beyond will increase the signal to the reverb tank?
IF you have not already checked your voltages in the reverb section, I would do so in order to rule out any error in that regard.
With respect, 10thtx
I added a 220k resistor on the send pot & it made a big difference in the right direction, Im thinking of changing that pot to 1 Meg. Should I do anything to the return pot? . . All the voltages are right in line with whats on the layout, I did try jumping the 10K dropping resistor to up the voltage but that did nothing other than raise all the voltages. . . Joe
telentubes
My 50 watt JM Sig is the opposite. My send and return are on 1.5 with tons of reverb available. I could use less.
- norburybrook
yep, I've never had mine past 5, I think there's something going on here that's not quite right.telentubes wrote: ↑Wed Jun 27, 2018 12:42 am My 50 watt JM Sig is the opposite. My send and return are on 1.5 with tons of reverb available. I could use less.
M
Rockwell666
nice clean build man!!
The deep switch is fairly subtle, but the mid should give a nice boost. Something doesn’t sound right there. Can you do a better pic of the switching area, hard to see cause the switches are underneath.
What reverb tank are you using? Doesn’t look like a 9AB3C1B style? Could be impedance issue?
Thanks,
Aaron
Thanks,
Aaron
Regarding the Deep switch I found it had more of an effect when playing at lower volumes.
Regarding your reverb try opening up your master volume more ( turning more to the right) if you haven't already.
Cheers
Guy
Cheers
Guy
