Greetings... how 10 years fly by...
There are a number of schemes and layouts of Dumbleator here, while my interest is in a bulit-in PARALLEL FX loop for a new build. By the way, I see no purpose in serial FX loops. Anyway...
There is a lot of work in that domain by a member bluesfendermanblues. but still I wander what is the scheme of the best, tried and tested in actual builds by members, PARALLEL FX loop, based on one ECC83 (12AX7) valve? Would someone who has made at least one amp with good implementation of parallel loop direct me to a proper scheme and layout? I have noticed a very elegant solution borrowed from MESA amplifiers and consider that useful, but I wander is it tested and built by someone... THANK YOU IF YOU SHOW ME THE WAY...
This FX loop is for a upcoming 0124 clone build based on 2x EL34 output.
						Best Dumbleator-like built-in parallel one valve FX loop
