If when I pop the OD relay board out on Thursday and something is wrong physically with the board I might as well use hoffman's as there are no proprietary connections on them, just eyelet to pin.10thTx wrote:One option may be simply to use Hoffman's relay board & relay socket IF it is compatible with the relays you already ordered.
I agree, and it is only the clean/od relay that is the issue.10thTx wrote: IF you did that & the problem was only the clean/OD relay board, then the issue would be resolved very easily. I typically get my parts from Hoffman within two days of ordering them.
Just another consideration.
With respect, 10thtx
You know, I really can't imagine that something is wrong with the current board unless a trace pulled up or like was mentioned before a piece of one of the resistor leads I cut lodged itself somewhere it shouldn't be.
I will find out on Thursday and post back.
