FINALLY an OD box that REALLY does Dumble tones!!!!
Re: FINALLY an OD box that REALLY does Dumble tones!!!!
I disagree I don't get anything from listening to the video's about this new OD pedal? But I keep chasing the honking tone around and can get that from several amps one based on 5f6a circuit with mixed hi/lo first triode, 6L6GC cathode bias. V1a 220k/3k3/1uf and v1b 180k/2k2/1uf.
Re: Sky Blue
Phazor wrote:That is an impressive sound from a pedal. The Tasty Guitar chops also help.
Thanks, I appreciate it.
UPDATE: I received my new pedal from a MP dealer who PROMISED me there were no changes to the circuit, just the stencil on the box that now says "hand wired' where the older one I have (borrowed from Mcdaddy) says "BJF design". (The change in housings worried me) Wrong.
VERY GOOD VERY GOOD!
- JazzGuitarGimp
Tag,
I would contact MP directly and explain your situation with the puppy eating the knobs on the new pedal. Ask if you can buy a new set of knobs from them. Probably won't cost you more than ten bucks. Then, once you've replaced the knobs, return the pedal to the dealer you bought it from. If you contact MP by email, it may be a goid idea to attach a picture of the eaten knobs.
Good luck.
Good luck.
Tag,
When life gives lemons, make lemonade:
Dog Gnawed Knobs™
> Mouthwatering K-9 olfactory audio enhancement - It's a well known fact that our dog friends have superior hearing. Part of the secret is their unique biochemistry. Now you can leverage the benefits of their unique biochemistry with saliva-infused-knobs (S.I.K.).
> Dog Gnawed Knobs™ provide tactile control you can sink your teeth into! Even on dark stages! For the first time ever, you can dial in you controls blind-folded by the unique and indelible imprints on the control knobs. No more fumbling around in the dark trying to find the sweet-spot using inferior human hearing alone.
> Each, and every, Dog Gnawed Knobs™ product is singularly unique. No two are the same. Add value and improve the cosmetics of your tone machines simply and effectively. Dog Gnawed Knobs™ add value to your equipment!
(laughter is the best medicine)
Hope you are able to salvage the situation. Good luck.
Dog Gnawed Knobs™
- Reeltarded
haha
Dogpile Underdrive
Dogpile Underdrive
M Fowler wrote:I disagree I don't get anything from listening to the video's about this new OD pedal? But I keep chasing the honking tone around and can get that from several amps one based on 5f6a circuit with mixed hi/lo first triode, 6L6GC cathode bias. V1a 220k/3k3/1uf and v1b 180k/2k2/1uf.
Hey Mark,
I will do a clip switching from 183s overdrive channel to the clean with the Sky blue. Its as close as it can be. Two samples of the same exact amp will not sound any closer. Even with the new pedal I can do it. Its totally amazing, and I did not think possible. If you have followed and of my posts over the years, you know what a pedal OD hater I am. For me to give in to a pedal, it has to be REALLY, REALLY good.
That looks like the exact thing!!! Thank you! I looked inside the pedal, and I can see one difference right away. 3 leads coming of the input jack Vs 2 on the older pedal.
Stereo jack vs mono jack on the input?
A stereo jack is often used on pedals to disconnect the battery when no plug is inserted into the input.
Dave O.
Dave O.
Ah he means me , Not the MD that make's pedal'sM Fowler wrote:Good thing I'm not rich I would have the Strymon Flint, Ola, Lex, and El Capistan great products from that company.
Tag I will have to check out McDaddy's website again was there not so long ago but don't remember the Bluesky pedal.
Check the video out below. So its clear, I have a totally clean tone dialed in on the Quinns clean channel, and an overdriven sound I use all the time on the drive channel. At the same time, I stamp on the Quinns channel switcher and the Mad Professors on off switch. So you are hearing the clean channel of the Quinn with the Mad Professor, and the dirty channel of the Quinn without it. I don't think you can get any closer than this, its pretty much dead on.
http://www.youtube.com/watch?v=YxumqnF3 ... e=youtu.be
Tag, they were dead on I agree hard to tell the difference. Sounded good.
Yeah I figured that out yesterday.Mac Daddy wrote:Ah he means me , Not the MD that make's pedal'sM Fowler wrote:Good thing I'm not rich I would have the Strymon Flint, Ola, Lex, and El Capistan great products from that company.
M Fowler wrote:Tag, they were dead on I agree hard to tell the difference. Sounded good.
Whew! I thought you were going to say they were not even close.
Not sure if it's just the recording or what but the pedal OD sounded more flat and one dimensional to me. Kind of like it was missing the depth of the amp's tone. It's definitely less bright and clear than the amp in the video above.
Have you tried them both together at gig volume yet? I'm guessing it was fairly quiet in the clip since I can hear your guitar acoustically when you hit the strings hard.
-Aaron
-Aaron
