Brown Note Blue Monkey 88 build..Finished, *Issues Fixed*
Blindog
Post by Blindog »
So I got this about 4 years ago (was one of the lucky ones to get a kit shipped before things went south at Brown Note) and then we had to relocate from Ohio to Atlanta Ga area. I finally got my workspace set back up and I'm stoked to get this sucker built.
Here's some pics of the progress so far.
Special shout out to the Amp Garage community. I was able to build my first amp about 6 years ago with the help of this community, a D clone from an old Fender Bassman 10, and I've had the bug ever since 8)
dcribbs1412
Re: Brown Note Blue Monkey 88 build..Finished, *Issues Fixed*
Post by dcribbs1412 »
Looking good Blindog
Those where nice chassis.
What iron you using?
Darin
Blindog
Post by Blindog »
Thanks Darin,
The iron is Heyboer, the PT has a Brown Note sticker with the part number so I'm sure Moss had them made.
Yeah, I'm really pleased with the chassis and the components...'cept they sent me 5m1 grids stoppers instead of 5k1, so I went through my stash of resistors and found some nos 1W 4k7 carbon comps, and measured until I found 4 close to 5k1 ;)
Blindog
Post by Blindog »
Cool, I might be asking you some questions! Thanks for the pics!
Blindog
Post by Blindog »
Finished...now for the smoke test!
dcribbs1412
Congrats Blindog
looks good...how did the smoke test go?
Darin
Blindog
Post by Blindog »
Hey, thanks Darin!
Well, fired her up with the trusty light bulb limiter, no problems...applied full power, and I couldn't get one pair of 6L6's to bias..the pot had no effect. Powered down and did some checking, and the 24K resistor from the bias pot to ground was wide open...go figure! Popped a new one in and all is well there now.
Everything seems to be working OK, except for 2 things that have me scratching my head:
1. The OD Drive control doesn't do anything when adjusted...maybe a hint of change when turned all the way up...
2. The reverb is working, but I get a 60hz hum in the background when turn up the control.
Anyone have some thoughts? This is my first HRM build, as well as a build with reverb. I've attached a copy of the layout from Brown Note.
JazzGuitarGimp
Post by JazzGuitarGimp »
The reverb tank has a transducer in it that is susceptible to stray electromagnets fields (much like a guitar pickup). The end of the tank that connects back into the amp's return input needs to be kept away from the power transformer as well as the power cord.
Blindog
Post by Blindog »
JazzGuitarGimp wrote:The reverb tank has a transducer in it that is susceptible to stray electromagnets fields (much like a guitar pickup). The end of the tank that connects back into the amp's return input needs to be kept away from the power transformer as well as the power cord.
Gotcha...I'll do a 180 on the tank when I put it back in the cab. I bet it'll take care of that hum...now to track down the OD drive control issue..
Many thanks!
Bob-I
Post by Bob-I »
For the OD control, check the ground on the pot as well as the pot itself. If the ground is not solid you'll get a very slight change as you turn the pot. You should be able to almost silence the amp with the OD at 0.
FYI, its a good idea the check every component as you build, measure the resistors and caps, check the pots sweep and switches function.
Blindog
Post by Blindog »
Bob-I wrote:For the OD control, check the ground on the pot as well as the pot itself. If the ground is not solid you'll get a very slight change as you turn the pot. You should be able to almost silence the amp with the OD at 0.
Hey Bob, good to hear from you! I checked the drive pot (in circuit) and it measures out ok...also reflowed the connections, no dice :?
Also, my voltages seem to be quite low:
V1a 129v, V1b 129v
V2a 115v, V2b 110v
V3 119
V4a 167, V4b 176v
Output tube plates 434v (seems ok)
I haven't modified the dropping string, it's per the layout. On a positive note, I was able to eliminate the reverb hum with a different tank orientation.
Stumped!
Blindog
Post by Blindog »
So I was staring at the schematic of the Bluesmaster in the files section trying to solve my drive pot issue, and I kept thinking it had something to do with the HRM. Sure enough, I had the input to the HRM stack connected to the 220k plate instead of the 150K (these are the values on the layout). The layout shows an arrow pointing to the 220k side for the connection to the slope resistor on the HRM board...flipped the connection and all is well!
So now I can start tweaking 8) I'm still wondering about my preamp voltages though...I'm hoping someone that built this circuit can chime in..
Thanks for everyone's input.
67plexi
Post by 67plexi »
Did you run a jumper wire from B+1 to B+2 if not do so and did you get B+4 and B+5 backwards
looks like it from your voltage readings.
