Ceriatone 50 watt HRM
tjauernig
Post by tjauernig »
Anybody out there used any pt's and ot's other than Mercury in these?
T. Jauernig
IcemanB52
Hammond Xfmers
Post by IcemanB52 »
I typically use the 290DX and 1750M from http://www.radiodaze.com/ in my builds. I haven't seen any conclusive information that the Mercury's sound better. If you do a search, I'm sure you'll find several threads on this topic. Cheers, Richard
JD0x0
Re: Ceriatone 50 watt HRM
Post by JD0x0 »
also just remember theres no such thing as "this or that transformer sounds BETTER" with guitar tone theres only different, member A might love transformer X while member B might hate transformer X and love transformer Y.
The only thing you can really do is buy some quality trannys and hopefully they sound better to you, and then the stock trannys are good for backups.
Personally i really dont think that the mercury magnetics are worth the money for these amps simply because there are so many good choices out there for dumbles. But a hiwatt, for example, works best with their partridge design, MM might work better for that application just because of the fact they clone the old partridge trannys and it'll probably be cheaper than a NOS(if you can find one)
rvf263
Re: Hammond Xfmers
Post by rvf263 »
IcemanB52 wrote:I typically use the 290DX and 1750M from http://www.radiodaze.com/ in my builds. I haven't seen any conclusive information that the Mercury's sound better. If you do a search, I'm sure you'll find several threads on this topic. Cheers, Richard
Have you ever used the 291DX?
It's suppose to be an upgrade but costs about $40 more.
I wonder if it's worth the upcharge.
RvF
IcemanB52
291DX
Post by IcemanB52 »
I looked at the data sheets from hammond, but the difference between the normal unit and the upgraded one wasn't obvious (atleast to me).
rvf263
Re: 291DX
Post by rvf263 »
IcemanB52 wrote:I looked at the data sheets from hammond, but the difference between the normal unit and the upgraded one wasn't obvious (atleast to me).
That's good to know, I just went with the 290DX.
RvF
LPSGME
Post by LPSGME »
Anyone have an opinion on how the stock HRM/OTS Ceriatone OT xformer sounds in comparison to others?
JImmyD
Post by JImmyD »
LPSGME wrote:Anyone have an opinion on how the stock HRM/OTS Ceriatone OT xformer sounds in comparison to others?
The build quality MAY be spotty on the OT's. Mine sounds OK to my ears especially at volume, and my buddy complains that his is down on power. He has good ears so his opinion counts. I do think my amp sounds a little dull to me at times. I know it can be tweaked a bit (or alot).
Is there better iron out there then what Ceriatone uses?
Without question. Do I know what it is? Not yet, but a careful reading of this forum provides many opinions! :-)
In the end, all it takes is money and time.
Jim - coming up on two years of OTS ownership
Guitarman18
Post by Guitarman18 »
True, there have been a number of posts where people have reported what seems like an unusually high number of failures.
Cheers, Paul.
