Express Documents
Trainwreck schematics, designs, pictures. Only members may post files here.
JPGraphX
Re: Express Documents
Post by JPGraphX »
Hi all!
I've started to buy my parts but I can't find some parts:
Aluminum capacitor : Mallory TC78 40uf
Aluminum capacitor : Mallory SKA100M100 10uf
Aluminum capacitor : Mallory SKA220M025 22uf
MOV / Varistor / Spike Protection: Metal oxyde AVX VE17M00151K
Thanks for your help!
JPGraphX
JPGraphX
Zippy
Post by Zippy »
This is supposed to be a thread dedicated to Express documents - not searches for parts or build support. There are other parts of the forum for that.
vibratoking
Post by vibratoking »
+1
It would be nice if a mod could remove this stuff so that it doesn't contaminate this sticky forever.
Ron Worley
Post by Ron Worley »
I'll throw him a bone..
The Mallory TC series are not that plentiful and stoopidly expensive. RJ Guitars was selling some a while back. Personally, I'd use F&T if I built another one.
The other smaller caps can be substituted with similar Mallory caps. Or try something else for flavor. These were chosen as reasonable subs for what Ken used, they are not gospel.
For the MOV, just find a similar variant, again, not gospel.
Ron
dariez75
Post by dariez75 »
Mallory doesn't exist anymore, was acquired by Cornell Dubilier years ago but the capacitors code are the same. These are Mouser's codes about... 598-WBR40-350A, 598-WBR20-450A. They are very expensive. I used F&T and TreC. Sprague Atom are still suitable but ever expensive.
Cheers
Matthews Guitars
Post by Matthews Guitars »
Would any of you have created a drawing of the basic Express front panel layout with legends, in a computer readable format such as something compatible with Adobe Illustrator, or in PDF format?
My front panel plan is to have it laser burned on curly maple, including the artwork and portraiture.
Colossal
Post by Colossal »
Matthews Guitars wrote: Sat Apr 26, 2025 4:33 pm Would any of you have created a drawing of the basic Express front panel layout with legends, in a computer readable format such as something compatible with Adobe Illustrator, or in PDF format?
Here is a PDF which is to scale and a match for the RJ Guitars Express reproduction chassis. I can make one to your specs if your hole spacing is not to the traditional values. I've had these laser engraved on wood before to great success.
TW Express Faceplate.pdf
Matthews Guitars
I used a Modulus chassis which I expect is standard Express pattern.
Here's a photo of the near finished amp. (Just needs that front panel.)
Colossal
Post by Colossal »
Sweet amp
Matthews Guitars
Because I don't see it mentioned in the BOM, what's the "correct" kind of knobs to use on an Express clone?
