LND150 pre on input jack
Design and discussion around PCB Design that doens't suck!
maxkracht
Re: LND150 pre on input jack
Post by maxkracht »
Seems obvious in hindsight, but my switching problem was easily remedied by using a TRS jack and using the ring to switch the input instead of the tip... Another revision...
https://oshpark.com/shared_projects/LYY97Xoa
Tip and ring switches are left floating, pad next to each is to create a solder bridge to connect whichever one you want.
