Page 1 of 2
Extension jack for Transformer mounted on speaker
Posted: Sat Dec 25, 2021 10:19 pm
by angelodp
Hi, for this sort of arrangement, with an OT on the speaker directly, can I simply run wires from the tabs on the speaker to a jack (mounted on a rear panel) and use that for a larger speaker of the same impedance.
Re: Extension jack for Transformer mounted on speaker
Posted: Sun Dec 26, 2021 5:04 pm
by xtian
If you run a second speaker in parallel, you will be lowering the impedance seen by the OT. You could simply disconnect the OT secondary wires from the existing speaker and connect them to a jack. Then plug whatever speaker you want into the jack.
Posted: Sun Dec 26, 2021 7:55 pm
by angelodp
Ok sure, maybe set up an external jack from the OT and put a male jack on the speaker tabs,
Posted: Mon Dec 27, 2021 11:27 pm
by Phil_S
Yeah, LOL, I think we call that thing a plug. Right idea, hard wire the plug to the speaker, or use spade lugs that fit tightly. Just take care that they don't slip off the speaker tabs or you'll be running with no load.
Posted: Mon Dec 27, 2021 11:38 pm
by sluckey
I would use a switching jack and wire it such that with nothing plugged in the OT will be connected to the internal speaker. But as soon as you insert a plug the internal speaker is disconnected and whatever speaker is on the other end of that plug/cable will be connected to the OT.
Posted: Tue Dec 28, 2021 12:07 am
by angelodp
Steve, might you supply a quick schematic? This is for a speaker mounted transformer.
Posted: Tue Dec 28, 2021 1:01 am
by sluckey
Makes no difference where the OT is physically mounted...
Posted: Tue Dec 28, 2021 1:07 am
by angelodp
Re-working
Posted: Tue Dec 28, 2021 1:13 am
by sluckey
no
Posted: Tue Dec 28, 2021 1:26 am
by angelodp
This? Corrected for the 12A tabs
Posted: Tue Dec 28, 2021 1:35 am
by sluckey
Do you find your drawing easier to understand than my drawing?
Have you installed the iso transformer?
Posted: Tue Dec 28, 2021 1:37 am
by angelodp
Your schematic is quite clear, just trying to translate to a layout.... not good? Iso Transformer is on the way.
Posted: Thu Dec 30, 2021 9:53 pm
by angelodp
I am looking to confirm the impedance of this speaker and when I read the terminals I consistently get .5 ohms? Schematic calls for 8 ohm so I should be seeing about 6ohms on the meter. With the transformer mounted on the speaker, is that affecting my reading?
Posted: Thu Dec 30, 2021 10:03 pm
by martin manning
Definitely.
Posted: Thu Dec 30, 2021 10:06 pm
by pdf64
OT secondary is a short length of thick wire.
