Cube 1936 = finger joint insanity
A few years ago I set out to build the smallest 2x12 cab ever. I was deep in the evil clutches of the lunchbox amp mania and smaller was always better. I miscalculated the magnet depth and rather than grind or mill a 1/4" bevel on ceramic magnets I choose to put 10" speakers in. The cab sounded fine with some batting. The other feature of this cab was I wanted to finger joint all four sides but I couldn't make the corner geometry work. So I scrapped that design feature. In retrospect that was a fortunate failure as my jig at the time was so not up to the task.
Fast forward to the present. Now a 50 watt+ Marshall slut and in love with the 1936 cab having built two I decided it was time to revisit the cube. Not for the small size but to replicate the internal volume of the 1936 to see if the speaker orientation would make a difference. The other benefit was I figured out with the help of Legos [I'm storing my now teen aged son's stash] was how to make the corner geometry work with finger joints - use a corner block.
The initial cab is pine with the option of building a pretty one later - that plan has been scrapped as you will see below. The corners will be walnut and the leading edge will be double thickness leopard wood with the traditional 1" round that Marshall uses. Luckily I had built a new finger joint jig for the last curly maple cab as this cab would test the consistency of jigs and cutting techniques severely. I did have to build a new cross cut sled so damn big I named it sledzilla as it covers the top of my saw.
There are 110 joints [one of the reasons I scrapped a pretty wood version] and it was a marathon cutting session. I marked the bejeepers out of the four sides to ensure I didn't miss cut - so tired of going to the wood store for more. I have always enjoyed cutting / sanding pine works like butter. I only had one joint that was about .010" off and required a bit of wacking to encourage it to play nice.
[img:1024:685]http://i166.photobucket.com/albums/u119 ... ds7ihw.jpg[/img]
[img:1024:685]http://i166.photobucket.com/albums/u119 ... tb9oyh.jpg[/img]
[img:1024:685]http://i166.photobucket.com/albums/u119 ... 5aqnap.jpg[/img]
Angling the baffles back a 2° was fun with a center post.
[img:1024:685]http://i166.photobucket.com/albums/u119 ... nqyj0f.jpg[/img]
[img:1024:685]http://i166.photobucket.com/albums/u119 ... z6cm0j.jpg[/img]
The grill is angled and required a jig to hold the frame straight as the grill cloth was stretched and stapled - and unstapled and restapled and then unstapled and restapled.
[img:1024:685]http://i166.photobucket.com/albums/u119 ... bfjf93.jpg[/img]
Working from the sides instead of the ends yielded a result I can live with.
[img:1024:685]http://i166.photobucket.com/albums/u119 ... tvylc8.jpg[/img]
A bit of oil and a pair of Jim's magnificent Scumback J75LD's and it was ready to play. Took it to a jam session last night and it sounded like a wide dispersion 1936 - no weird artifacts or frequency loss. Sounded great with a JMP 2204 and magnificent with a Satellite Barracuda.
[img:1024:685]http://i166.photobucket.com/albums/u119 ... khlwr5.jpg[/img]
I haven't attached a handle yet as I'm not sure the best balance spot is. One side bummer - it's tall enough that it won't fit under my pickup bed cover when it is closed.
ampmike
Nice
Post by ampmike »
That is awesome,And great enginuity.Love it!!!
DenDanger
Re: Cube 1936 = finger joint insanity
Post by DenDanger »
That's a novel design! Beautiful work!
Kinda retro-futuristic look
Denny
Wow! If you said so, I missed it. How does it sound?
Phil_S wrote:Wow! If you said so, I missed it. How does it sound?
It sounded like a wide dispersion 1936 - sound everywhere. I'm not sure how to describe it differently. Other than the ability to 'spread the love' around I don't see any other benefits - no real detractors unless you have heads wider than 24".
Thank you all for the kind comments.
P.S. I'm in postpartum project depression.
Markusv
Post by Markusv »
That is sex
Its beautiful and inspirational
Markus
.........Now where did I put it?
RB
Wow
Post by RB »
I think you should rename your post to "finger joint mastery".
Very kool cab.
Regards
Randy
Thank you for all of the kind comments. It was a challenging itch to scratch and rewarding as it had no sound issues. Best of all it rocked out well paired with a 1936 with M & H75 Scumbacks pushed by a Satellite Barracuda, a pedal or two and a hard hitting drummer.
rooster
Post by rooster »
Wow, this is a novel creation. An amazing idea in guitar amp land and something I have not seen before. Cool! 8)
MakerDP
Post by MakerDP »
I'm wondering how well this would work in a small venue, when you aren't micing the cabinet.
If this cabinet was placed in the center of the stage is there a "dead spot" in the sound out in the crowd somewhere?
This arrangement would be awesome for stage-monitoring your amp for everyone to hear though.
BTW, very nicely done. I really like it a lot!
MakerDP wrote:I'm wondering how well this would work in a small venue, when you aren't micing the cabinet.
Thank you!
I suspect there would be a dead spot if this was the only cab. I doubt there would be bounce from the walls to compensate. Used with a front firing cab would be best or perhaps a beam director that angled half of the output forward. I may need to experiment with that.
