Page 1 of 1
Vox AC10 Twin Cabinet plans?
Posted: Mon Apr 01, 2013 12:09 am
by LeftyStrat
Anyone have plans or dimensions for the Vox AC10 Twin?
I know the outer dimensions are supposed to be 24" W x 18" H x 9" D.
I have plans for the Vox AC30 cabinet (attached). I suppose I could scale things from the AC30.
Re: Vox AC10 Twin Cabinet plans?
Posted: Wed Apr 03, 2013 12:31 pm
by Phil_S
If I were doing it, I wouldn't sweat too much about the exact dimensions. As you know, a 10" board is really 9.25". Just go with that in 1" (really 0.75") thick lumber and I predict it will work out just fine. An 8' board is 96" and after you square it properly it still has enough for you to cut the 4 boards you'll need for the basic box. If you are going for a pair of 10" speakers, I think you'll do just fine with a 24" wide baffle (easy multiple for standard 4' x 8' ply) and I'd shoot for building around that dimension. For a 24" baffle, the outside cab width will be 25.5", which is just a hair smaller than the AC30 cab and nearly consistent with what you report are the correct dimensions. OK, that's my 2 cents!
OK...a quick search turns up photos here:
http://www.thevoxac30guide.com/vintage_ ... ction1.htm about 25% of the way down. There is enough visual information in these pictures, based on the speaker diameter to estimate the correct size of the cabinet. This is for a single speaker.
Posted: Sat Apr 06, 2013 2:03 am
by LeftyStrat
Thanks Phil. That and the out dimensions should get me there.
Posted: Sun Apr 07, 2013 3:21 pm
by Phil_S
His email is at the top of the page. It's worth asking if he will measure and send you a few detail pictures.
Posted: Sun Apr 07, 2013 3:52 pm
by LeftyStrat
Phil_S wrote:His email is at the top of the page. It's worth asking if he will measure and send you a few detail pictures.
Unfortunately, I realized that AC10 in his page is a single speaker AC10. I'm looking for the 'Twin' which was a 2x10.
I think I'll still email him, he has probably come across one.
Posted: Sun Apr 21, 2013 9:50 am
by rp
Took a while to get this scanned as I've no ink and guess what happens w/ your HP all in one printer when it has no ink?
If you still need, this might help. I did this 20+ years ago so I've no idea how accurate I was being. On the other hand it has the centering for the logo
I know it looks like like a 6 year-old did it but it was a very quick sketch, ok?
Posted: Sun Apr 21, 2013 4:35 pm
by LeftyStrat
Awesome! Thank you so much!
