some time ago i was lucky enough to score this panel integrated Top Boost AC30 from 1964. It is one of supposedly less than a 100 copper panels with the integrated top boost. ( i would appreciate a hint towards the source of this info btw.)
It sounded nice as is, but once i changed to some old unbranded el84's it sounded phenomenal. At about 6 and above on the Top Boost channel with Treble at anywhere between 7-10 and Bass 7-10 it easly gets into Marshall Plexi style tones - with slightly less low-end, but with that soft, singing and spongy feel, incredible string definition even when driven hard and not the faintest hint of harshness. And of course, when you crank it past 6 on the brilliant volume, you get that hot fire-breating VOX drive thing. It is also a very quiet amp, less hum than my jtm-45/100 clone and no noticeable ghosting. I own 6 vintage amps or clones thereof, which many would consider iconic and the AC30 turned out to be my favorite (after the tube swap). Also the clean up with volume and the dynamic response of the amp are truly incredible. I know, everyone has been raving about it, but it is really an experience to try that yourself. It is a phenomenal blues amp that lets you explore all of those rolled back guitar volumetones, while still sounding dynamic and alive. For some reason it also sounds massive recorded. It sounds fatter and bigger than my big amps (DR504, OR120, JTM 45/100). I am sure the big amps have way more bass response, but to the ear, recorded the AC30 sounds "fatter" and just massive. I assume part of that is the compression, which helps it sound louder and part of it is some low mid frequency that i would call a "push", which is behind the AC30 and which i do not hear in any other of these amps - this gives it the feeling of punchyness and a very dynamic nature. If i had to choose just one amp, with a gun to my head, i think this might be it - it kind of does both - clean AND mean better than any of my other amps. Takes pedals perfectly as well. Harder to dial it in on the TB channel, but normal channel with pedals is an easy recipe for success
At some point i will try to clone it (minus the vibrato channel) and add an EF86 channel instead.
Here are 2 clips i did. One is with an ES335 copy (Yamaha SA-1000) and the other one is a 62 hot rod Fender Strat, no pedals. That is recorded DI and with an added Impulse response of a 2x12 cab with greenbacks. (I prefer these over the alnico sound). There is no EQ or other post processing, not even a room sim. If you would a room IR, it would sound absolutely massive.
https://soundcloud.com/vintagecharlie/1 ... t-es335-sa
https://soundcloud.com/vintagecharlie/1 ... oost-strat
