Hiwatt DR504 clone build - burning power circuit resistor
Vox and Hiwatt Discussion
eahudimac
Post by eahudimac »
Hi. I just completed a DR504 clone. Upon powering up with no tubes installed, the 220K resistor on the power circuit filter cap instantly burns up. The only components between it and the power transformer are the rectifier diodes. The wiring diagram is attached. One thing that is different are adjustable bias pots for each tube and test points. Any idea what might be causing this?
Re: Hiwatt DR504 clone build - burning power circuit resistor
Is the value correct, 220k ohms?
eahudimac
Post by eahudimac »
Yes, I checked the resistor prior to sautering in. It was very close to 220k ohms.
sluckey
Post by sluckey »
Can you verify the band colors on that resistor and the other one soldered to the other cap? My monitor thinks the colors 'may' be red, red, brown, silver.
pompeiisneaks
Site Admin
Post by pompeiisneaks »
agreed, that third band should be yellow, not brown, if it's brown, its 220 ohm and that would burn up fast at that voltage.
~Phil
tUber Nerd!
eahudimac
Post by eahudimac »
Yep, it's brown - 220R. Thanks for noticing that! Will have to order the 220Ks.
sluckey
Post by sluckey »
I highly recommend using a two or three watt metal oxide resistor for both of those 220K bleeders. For sure, don't use 1/2W carbon comps.
JD0x0
Post by JD0x0 »
sluckey wrote: Mon Dec 23, 2019 6:29 pm I highly recommend using a two or three watt metal oxide resistor for both of those 220K bleeders. For sure, don't use 1/2W carbon comps.
This. Carbon Comps are probably the worst choice for power applications. They drift, they crack, they absorb water, they're generally not very reliable. There's no advantage using them there, even if you believe in the 'Toan Mojo' of CC's you don't get it using them as bleeder resistors. Plate resistors will be effective if you want that 'resistor distortion' Also worth noting that I believe Hiwatts often used carbon film, not carbon comp.
It's true i've lost my marbles and i cant remember where i put them
