Muchless Spit Build
Vox and Hiwatt Discussion
fusionbear
Muchless Spit Build
Post by fusionbear »
This is a fun one I just started today. Hope to finish by the end of the week.
[img:3264:2448]http://i.imgur.com/CbndxNf.jpg[/img]
[img:3264:2448]http://i.imgur.com/crfzHbN.jpg[/img]
[img:3264:2448]http://i.imgur.com/5jHUUQh.jpg[/img]
[img:3264:2448]http://i.imgur.com/VtJvTZV.jpg[/img]
Learning to learn...
Re: Muchless Spit Build
The Matchless Spitfire is a good circuit and I used one for gigging for several years. To cut through the mix I simply relied on my pedal board effects to help me through.
The fat switch doesn't have much apparent effect.
Have fun.
pdf64
Post by pdf64 »
Nice!
Very tidy Merlin style heater wiring.
What chassis is it (I assume you haven't done those cut outs for the transformers)?
jelle
Post by jelle »
Nice!! :D
Jelle
fusionbear
Amp is done and it came out really well:
[img:3264:2448]http://i.imgur.com/NLLvlTH.jpg[/img]
[img:3264:2448]http://i.imgur.com/aCG64xJ.jpg[/img]
[img:3264:2448]http://i.imgur.com/xXxNEx6.jpg[/img]
https://www.youtube.com/watch?v=WVKYCdigKkc
joeboo88
Post by joeboo88 »
fusionbear: nice job and it sounds awesome!
from your pictures on your version of the PPMIV I don't see the usual 2M
resistors across the lugs, how did you wire that up?
I see lug 1 to ground and ??
I want to build a Spitfire and maybe add an EF86 channel
and employ your MV
I also listening to your 1986 Plexi Build video....Wow
thanks in advance, Joe
fusionbear
joeboo88 wrote:fusionbear: nice job and it sounds awesome!
and employ your MV
One lug goes to ground and the other goes to the input of the power tubes. There is always a 250k reference to ground for the screens. No need to use extra resistors. The wiper is the input.
