Mark wrote:R.G. I noticed your version has op-amps in it, while I'm sure no one notices the difference, what was the motivation to use op-amps?
Was it real estate or were the transistors used leaky germanium types which are impossible to find?
Actually, none of the above.
There are no opamps in it. The circuits are the same, resistor for resistor, cap for cap, transistor for transistor with some very minor exceptions:
- No self respecting power supply designer would make a power supply like the originals today. Instead of using dropping resistors and capacitors to get different voltages, I dropped in three-terminal regulators. This let me put the whole power supply for the preamp board actually on the preamp board, not on wires to the tag strips in the "basement" under the PCB. Fewer wires, lower noise, more reliable performance.
That's what those TO-220 packages are.
- The two 16 pin dips you see are not opamps, they're CMOS analog switches. The originals have a 4P3T rotary switch used to select which channel gets the reverb. That's at least six wires onto/off the PCB all carrying signal and therefore prone to noise, hum, and breaking. I replicated the switching, but using CD4052 switch chips, on the PCB itself.
The rotary switch now only switches the control signal to the CMOS chips, which do the same switching the old rotary used to do. I know there are purists who will say that this causes an unacceptable loss of "tone"
, so I put two extra pads and jumper locations on the PCB so die-hards can leave off the analog switches and do it the old (hard!!) way.
The rotary switches in the original are prone to bad contacts, and although they can be replaced, the CMOS setup only requires one of the four sections work to reused the old switch mechanism.
The other change from the original on that PCB is in the relays. The original V1141 and it's smaller brothers used two relays. One bypasses/enables distortion, the other does MRB. The relays have the same issues as the reverb switching - analog signals go off the PCB somewhere else on the chassis, and raise issues of hum pickup, noise and breakage. I put a $3.00 micro relay on the PCB for the distortion switching; it's the orange rectangle on the left edge of the main PCB.
I also adopted the JFET switching from the next-generation V1143 to switch the MRB effect, replacing the off-board relay. The relays are no longer available; replacements could be found, but would be more expensive. So I sidestepped the relay issue.
The fundamental design objectives for this board were:
1. Have it mount exactly like the original.
2. Declare war on wires: any wire that did not absolutely have to be there was removed. The wires were the problem with the originals.
3. What wires had to be there would all come from one edge, eliminating the Gulliver-in-Lilliput tie-down of the board with wires from everywhere.
4. Wires would go from the board to the control/jack/switch and be as short and direct as possible. Ideally, there would be no wires crossing. For all the pots, for instance, there are three wires from PCB to pot, and they are always in the order CW/wiper/CCW on the PCB edge.
5. Wire paths were set up so that, unlike the original, the PCB can be rotated up 90 degrees so you can get at the solder side and component side for repairs without breaking wires in laced bundles.
