Mustard cap substitute!
-For Hiwatt clone project-
what can I use for a good substitute to the MUSTARD caps?
Sozo , Mallory..?
any suggestions are appreciate!
S.
Sozo , Mallory..?
S.
AcornHouse
Re: Mustard cap substitute!
Doug is stocking Mojo Dijon caps.
http://hoffmanamps.com/MyStore/perlshop ... =!ORDERID!
Thanks , but honestly I would not buy in the US, but in Europe!
S.
S.
Thanks Jelle!!
Note that the word is that the Mojo mustards are polypropylene film and foil not polyester. I remember looking into this and found confirmation on a seller's site somewhere, maybe even mojo's. No big deal, and making no judgement of tone as I haven't used the ones I have yet, but if shamanistic fetish talisman voodoo is a part of your process maybe you want to know. The sozos are supposedly polyester and foil. The mojo's are pretty big too in diameter, bigger than I expected from something claiming to be mustard copies.
TAD & Mojo are be same I think.
Yes, but apparently some people really like them. Never hurts to try them...
I just built another DR504 clone for a local bass player----- I used a mix of Mojo Dijon and M150's----- the 47n Mojo Dijon caps are very large in diameter so I used M150's in the 47n and 100n board positions for a neater fit.
I still had enough yellow M150's to do the job.
FWIW----- George M. (Metro) wrote that he found that the closest new cap in tone to old Mustards are the white M150's.
I can't confirm this because I used yellows on this build to keep everything to a similar color scheme on the board.
It was satisfying when the customer's eyes lit up when he first played this one------- he is very happy with it.
Heyboer Partridge clone iron from Mojotone................. gldtp99
Just bought some of these http://www.newark.com/vishay-roederstei ... -G-SKU-MDC
Gonna give 'em a try.
1 sozo next gen
2 sozo vintage
=3 sozo standard OR mallory 150
5 TAD/mojo
2 sozo vintage
5 TAD/mojo
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Allright.
I recently tried the white M150 in the OD section of an Overdrive Special, and absolutely hated how it handles distortion. If the TAD ones are worse sounding...
Must be an application thing. Still never hurts to try.
the TADs ones sound bright and perhaps even harsh
4x12" w/H75s
4x12" w/H75s
I'm probably the only guy on this forum that really likes Xicon Metalized Polypropylene MPP caps
Oh, you're not alone.M Fowler wrote:I'm probably the only guy on this forum that really likes Xicon Metalized Polypropylene MPP caps
