Hiwatt PA50 - questions
Vox and Hiwatt Discussion
ronin
Post by ronin »
Hello all. I recently got a '73 Hiwatt PA50 from the UK (I'm in the US). Overall the amp looks to be in good shape. Not abused. It even still retains its original capacitor cans (which all show tell tale bubbles on the ends so I'll be replacing those first). I wouldn't be surprised if it hasn't been used much since the '80s. Lots of dust inside. It does have a tech inspection sticker from '99, so someone showed it some love then.
From looking it over closely (and comparing it to another PA 50 I found an old Reverb listing of), I think there are 5 changes from when it left the factory (or garage?) of Mr. Reeves.
Here are some pics to give you a feel for the amp:
And an overall shot of the inside:
I'll post more detailed photos and questions below as I don't know if there is a text or photo limit per post or not.
ronin
Re: Hiwatt PA50 - questions
Post by ronin »
In no particular order, here is change #1:
Small capacitor change (the black Jackson one). My amp:
Comparison amp (blue capacitor):
Besides the change of capacitors, it looks like the original is 100uf and the replacement in my amp is 10uf. Would that change affect the sound/tone any? If so, any ideas how it might affect it?
Also is the blue capacitor a Vishay capacitor?
ronin
Post by ronin »
Change #2:
In the same general area, on the EL34 sockets, some resistors were added (1 per socket). Any 8dea why these were added? To help more modern tubes not overheat? Something else?
Also I am having difficulty reading the 5 band codes on these and hoping someone can enlighten me.
A couple of pics of my amp:
And the reference amp, it's just a solid wire to ground:
Here's a close up of one of the resistors in my amp since I can't zoom in on the other pics. Hope it helps to clarify the colors of the bands.
ronin
Post by ronin »
#3:
Change of a capacitor, from a mustard .022uf to a 223J capacitor (which is supposed to be .022uf).
My amp:
Reference amp (towards the right end of the turret board):
ronin
Post by ronin »
#4:
A resistor change towards the other end of the turret board.
My amp:
Reference amp:
If I am reading correctly, both are 22k resistors. Please correct me if I am wrong.
Also, is the original resistor an Iskra brand? If so, what wattage, 1/2w or more?
ronin
Post by ronin »
#5:
I didn't actually take any specific pics of, just a change to the jack for the power cord, from the original round bulgin connector to the current IEC version.
sluckey
Post by sluckey »
ronin wrote: Sat May 31, 2025 8:13 pm If I am reading correctly, both are 22k resistors. Please correct me if I am wrong.
Wrong. red/red/red = 2,200Ω. red/red/orange is 22,000Ω
ronin
Post by ronin »
sluckey wrote: Sat May 31, 2025 9:01 pm
I apologize, I was hoping the pictures I posted would be larger, but they are not and hence a bit difficult to see. I zoomed in on the reference amp resistor and I thought it looked red/red/orange, but let me know if you disagree.
The one to the left of the mustard capacitor.
sluckey
Post by sluckey »
The resistor next to the cap is 22K. And the resistor to the left of the 22K is 2.2K. They are not both 22Ks. Maybe I'm misunderstanding what you said? Are these the two resistors you are talking about?
ronin
Post by ronin »
That's my fault, I don't think I was very clear in my initial explanation. All of my comparisons are between my amp and the reference amp, and my focus is on what's different (what's not original) about my amp. Partially I am curious if any of the non-original parts on my amp are affecting the tone or not.
I hope that makes more sense. Again, sorry for the poor communication on my part.
sluckey
Post by sluckey »
OK, now I understand. Sorry for my confusion. :oops:
I doubt there's any sonic change by replacing the original 22K with a different brand 22K. A schematic would show exactly where that resistor is in the circuit. Heck, it may not even be in the signal path.
ronin
Post by ronin »
No worries, I didn't do a good job explaining in the beginning. I appreciate you trying to help me out. And thanks for the feedback on change #4 (the 22k resistor). By chance do you have any thoughts on the other changes, especially #1 and 2?
Thanks again for the feedback.
sluckey
Post by sluckey »
#1. I doubt there is a sonic difference. Probably measure a bit more ripple on the bias voltage in your amp. Hiwatt liked to use 100µF bias caps in all their amps. I suggest you change the 10µF in your amp to 100µF just because Hiwatt was fond of 100µF.
#2. The added resistors on your power tube sockets are used to simplify bias checks. They're a good thing. No sonic impact. I would leave them.
3#. Both caps are .022µF. I would leave it. I say no sonic impact. Others will say differently.
ronin
Post by ronin »
Thanks for the reply. I do appreciate the feedback.
For #2, can you tell what the code is for the resistor? I added a close up image above hoping that whould help.
Thanks again.
sluckey
Post by sluckey »
Brown-Black-Black-Silver-Brown is 1Ω 1%.
See for yourself... https://el34world.com/charts/resistor/5 ... isitor.htm
