which one do you find youself using more? despite the fact that they're very different amps...
thanks
						anyone built both a liverpool and a rocket?
Re: anyone built both a liverpool and a rocket?
I think you need one of each as they are so different or you can do like I did and build a 2 channel amp since both share sort of the same output section. You just need to build seperate preamps and figure out a way to mix two out of phase preamp stages together like in a Marshall 18w and then find a way to switch the NFB in and out and the cut control.riscado wrote:which one do you find youself using more? despite the fact that they're very different amps...
thanks
https://tubeamparchive.com/viewtopic.php?t=3026
