Hi guys,
I am having a problem running 34's in my Express clone.  When I am pushing the amp hard I get this crackle but only on higher pitched notes. Like the G B and High E strings above the 5th fret. The noise is on the leading edge of the notes and usually happens when I am picking hard.  I have found that putting a 12AT7 or 12AU7 in V1 or V3 solves the problem. It does not happen when I am running 6V6's.  I first noticed it on start-up when I was using new production EL34's.  I switched to NOS 34's and the problem seemed to subside but now it's back.  I haven't tried an AT7 or AU7 in V2 yet but I assume it will also solve the problem.
My thoughts are that the signal into the power tubes is too hot and needs to be tamed a bit.
Questions are:
A)Does a 6V6 take a hotter input signal than a 34?
                      B) Does anyone have any suggestions about how to best go about losing some signal before the power tubes without changing the amp too much?
I REALLY love the amp with 34's and want to use the new production stuff but I don't want to change the amp too much!
Greg
						Problem running EL 34's in my clone
Re: Problem running EL 34's in my clone
Interesting.  My amp was doing the same thing, but with 6V6 and EL34 tubes.  I traced it down to vibrating parts around the bright switch.  I found I could induce the crackle by tapping the chassis hard around the switch, which led me to think it was a volume/vibration issue.
Jake
						Jake
