I am putting together another Rocket build for somebody else. I'm not really bringing much to the table that is going to be new except a bit of an updated power transformer. I had Pacific wind some 120/240 mains Wreck transformers with a 5V rectifier tap. The OT is a Heyboer HTS-8093-1 Dynaco style.
For this particular build I'm also going to go with the JJ can caps and it all required a little trickery get everything to fit into the available space. I slid the power tubes slightly to the east to make a little more room for everything. I also added a heat shield to reduce the direct heat hitting the can caps. I've never actually done this or had any indication I needed it but it just seemed like a good thing to include.
I'm just finished with the initial wiring stages of getting all the transformer leads connected and ran some voltage verification tests.
532V AC on the PT Secondary (using the lower voltage taps)
5.4V AC on the rectifier tap
6.9V AC on the heater tap
The pilot light comes on and I get an ever so slight hum on the chassis when I power it up. More photos coming as I progress...
Edit - August 26, 2017 -- I have determined that I had the rectifier wiring wrong... look at the later photos if you have plans to copy my work
