Express el34 and two 25watt Greenbacks
RockinRocket
Post by RockinRocket »
Is this safe to do? I plan on building a express after I feel I have done enough research. The biggest cab I have is 2 greenbacks and am hoping I wont have to buy a pair of creambacks. I would attenuate but like most folks would want to hear how it sounds natural.
Also I am real interested of what typical clones put out for max output? Thanks for the help.
Roe
Re: Express el34 and two 25watt Greenbacks
Post by Roe »
should be safe imho
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
funkmeblue
Post by funkmeblue »
I run mine into 2
RockinRocket
funkmeblue wrote:I run mine into 2
With el34s? Where do you run the volume at and have you ever dimmed it? Thanks
Roe
Post by Roe »
the express is a small amp (6k6 around 400v, almost like a deluxe reverb). the output is less than 50w
4x12" w/H75s
JoeCon
Post by JoeCon »
Guys,
How about if you can only run a single 12" for the Express? What's a good choice?
Thanks....
redshark
Post by redshark »
I like celestion gold (louder). Some people say a creamback (65 watt) will tame the volume. For the gold I would recommend using 6V6's to be safe.
Gibsonman63
Post by Gibsonman63 »
I run a pair of Heritage 30's with mine. It handles it just fine.
RockinRocket
Roe wrote:the express is a small amp (6k6 around 400v, almost like a deluxe reverb). the output is less than 50w
Im aware the amps under 50 watts (clean though, right?) But Ive also read multiple times that the express is louder than 50watt 4 hole marshalls. Why would it have less watts but louder than 4 hole marshalls?
Scumback Speakers
Post by Scumback Speakers »
A single speaker with 50-65w power handling will handle an Express all day. Pretty sure they're around 30-33w clean, but no more than 50/55w maxed out.
They're louder than a JTM 45 which is a four hole Marshall, but not louder than a 1987 Marshall 50w amp.
Two 25w G12M's should be fine for an Express, IMO.
Scumback - Spring Break Sale!
sales@scumbackspeakers.com
www.scumbackspeakers.com
JoeCon
Post by JoeCon »
Jim,
Thanks for the info.
Also if you're doing a 2 speaker cab any preference in wiring and speaker resistance? Like two 8 ohm in series vs. two 16 ohm in parallel?
Thanks.
Scumback Speakers
I recommend two 16 ohm speakers wired in parallel to 8 ohms.
JoeCon
Post by JoeCon »
One final question about 2 12 greenback cab
Open or closed?
Thanks again....
RCGPNY1
Post by RCGPNY1 »
Either open or closed will be fine....Different tone. The speakers will have a little less power handling in an open back cab because orf excursion limits. I think for a margin of safety I'd use G12H30's....I think they sound better too(IMHO).
RockinRocket
Southbay Ampworks wrote:I recommend two 16 ohm speakers wired in parallel to 8 ohms.
Thanks for the detailed responses. Very good info. Im interested in why you recommend parallel for 8 ohms. I usually try for 16 ohms because of using all the winding in the transformers. Do I hear a difference? I dont know maybe.
