Rocket Pics on the gig
Painted head and cabinet
Re: Rocket Pics on the gig
Very Nice.
I need to do that to my Rocket and Rockster....
- JazzGuitarGimp
Hey rj, do you prefer your pedals on top of the amp, or was stage not big enough to put them on the floor?
- RJ Guitars
Nice looking rig! Would love to hear some sound clips too...
By the way, it's very cool that you are playing a Wreck clone right there in New Jersey.
rj
rj
http://www.rjguitars.net
Being that the top cabinet- without the handle and all, makes for a good platform- I usually only bring one or 2 pedals to a gig- and being in a building type of mode - I decide to build a pedal board - I never liked pedals on the ground anyway- never have room for that - So I cut out a 3/8 marine ply board slightly smaller that the top of the rocket-painted and finished it the same - and mounted the following - Fulltone trem - DLS Chorus ViBrato - Pork Loin- Aqua Puss- Boss RV3- The cabinet is Radiata Pine- lightweight- 3/8" BC pine baffle with 1/4" X 1" edge strip (what's the official name for that piece?) Sears "Whipped Mint" latex paint, Minwax Polycrylic Protective Finish - which is water based. Weber 15F150 30 watt speaker. I favor the 15 speakers. My settings are - cut - zero, bass- 3, treble- 3, volume- about 4/5ths of the way up. tone down 60% on guitar- Rocket does the old school - flat-low fi - sound like no other.
- Reeltarded
Stands out, love the paint!
You from Jersey? I'm from Jersey! What exit?
If you are close enough maybe I will come out and catch one of your gigs!
Amp looks great! I like the white!
Hi HeeBGB
Next gig Sat Nov 9th Smith Brothers Ridgewood NJ
51 N Broad Ave 8:30pm - 12:30 Am
Arthur Neilson on bass
Come down and play a tune on the Rocket- I'll grab the harmonica
Rocket at another gig
- RJ Guitars
Is that a 15 in the cabinet... I think you might have told at one time. I am curious which one you use and if the cabinet is open back?
Hi RJ- its a weber 15" - 15F150- 30 watt VC.
open back - with 3/4" square pine glued all around the opening.
I added a closed back, closed back with a hole in the center, top and bottom packpanels, single bottom panel. Sounds the best with no panels at all. Once I glued the wood to mount the panels, it changed the sound slightly- made it a tighter bottom. I was origionally running with no panels and no wood to mount the panels to. Every configuration has a different sound. I always tune to get the lows and the highs out. These new speakers have too many highs and lows.
Wanna drive over?HeeBGB wrote:You from Jersey? I'm from Jersey! What exit?
