Master Vol pre-Pi/post third stage is Baned??!
richon
Post by richon »
Has anyone tried it ?
I'm going crazy modding a Fender-ish amp with what was a dumble Overdrive which wasn't for me
Soy de Chile y tu?
sepulchre
Re: Master Vol pre-Pi/post third stage is Baned??!
Post by sepulchre »
I've got one in mine. But it's my first build and it's not exactly a TW clone - some differences. Plus I don't even have it voiced yet. But I can tell you, to get "the tone" I have to turn the master all the way up.
Edit: mine doesn't get "the tone" even with the master cranked. I have to remove it and even then it's got problems. So...
Firestorm
Post by Firestorm »
In that circuit, pre-pi master affects the tone. Post-pi master affects the nfb. Incredibly complicated subject, which someday I may attempt to understand.
pablogt
Post by pablogt »
I would try to put in IN the PI. That is, a bootstrapped mv....
Pablo
hans-jörg
Post by hans-jörg »
pablogt wrote:I would try to put in IN the PI. That is, a bootstrapped mv....
Pablo
Hello Pablo,
sry about this question, but do you have a schem with a bootstraped MV ?
Sounds interesting but I have no idea how it looks. All I find is "kathode amplification" or "anode basis circuit" :?
Best
Hans-Jörg
pablogt
Post by pablogt »
I used it on my Plexi.
https://tubeamparchive.com/viewtopic.ph ... ight=plexi
Very transparent...
Pablo
pablogt wrote:I used it on my Plexi.
Very transparent...
That's a great looking amp, Pablo! Where did the bootstrapped MV (dual pot version) come from? I looked at a bunch of MV discussions, including the one here on TAG ( http://www.ampgarage.com/forum/viewtopi ... highlight= ) but I don't believe I saw a source for that one.
pablogt
Post by pablogt »
I read about it first in Kevin O'Connor's books. Merlin also talks about it in his books.... Tried it and loved it.
Pablo
This MV is not in Blencowe, but he does discuss the "scale" control. I read that O'connor was the source of the circuit with the single 1M pot on the input side, but didn't see anything attributing the dual to him.
pablogt
Post by pablogt »
He calls it "London Power improved master volume" or something like that.
P.
Ah, thanks!
Interesting setup there. I noticed it in your build thread before but never looked so close.
hans-jörg
Post by hans-jörg »
Thank you Pablo,
I see now, its the "alternate drive compensation" of London Power Scaleing.
But does it work with the same "transpiracy" in a Rocket without P.S. ?
I will give it a chance, but first I´ll try with LarMar (the 2x250k is allready in and waits) and compare it than with the L.P.
Thanks again
Hans-Jörg
pablogt
Post by pablogt »
Actually, I prefer the Lar Mar ppimv in the Rocket. They have no NFB loop, so NFB does not decrease when used
P.
hans-jörg
Post by hans-jörg »
I understand. So if NFB is a matter better the bootsraped PI version.
If no NFB - the LarMar is the solution.
Merci
Hans-Jörg
