Transformer Mismatch?
d2camero
Post by d2camero »
I just finished my liverpool and am having a few problem with a high B+ (although line in is 115VAC). I ordered a set of trannies from Paul, and just realized that I may be using the wrong transformer.
For the liverpool PT what secondary voltage should be used ? 260-0-260 or 300-0-300?
Am also concerned about the output stage - what OT input impedance should be used for 4 x EL84? 5.2k or 6.6k?
thanks
d1
rhinson
Re: Transformer Mismatch?
Post by rhinson »
the output pri. you should use with that trannie is the 5.2k; use the 260-0-260 for your power trannie sec. rh
