Express bias range
				Randy Magee
Express bias range
Is it unusual to have to adjust the bias resistor to be able to get EL34s to the proper range?  With the 47K resistor I couldn't get even 50% plate dissipation at idle.  I had to drop the bias resistor down to 39K to get the proper range...
									Randy Magee
Re: Express bias range
What value is the resistor coming from the B+ to the bias supply?
				Randy Magee
If your screen and plate voltages are reasonably in line then that particular set of EL34's just needs a little higher voltage to reach a given plate current.
				Randy Magee
The plate voltage on both EL34s is 412 VDC... the screens are running 395 VDC... that seems pretty in line with what you'd expect... the strange thing is I have multiple tube sets that wouldn't get in range with the 47K R29 resistor... all's well that ends well, I suppose...
									Randy Magee
				funkmeblue
couldn't you get more range by changing the 47k resistor to 22k and the 25k pot to 50k?
				Randy Magee
Probably, but I already had the 39K and that put me in the ballpark...funkmeblue wrote:couldn't you get more range by changing the 47k resistor to 22k and the 25k pot to 50k?
Randy Magee
???Randy Magee wrote:The plate voltage on both EL34s is 312 VDC... the screens are running 395 VDC.
				Randy Magee
Typo... the plates are running 412 VDC and the screens 395... doh!Firestorm wrote:???Randy Magee wrote:The plate voltage on both EL34s is 312 VDC... the screens are running 395 VDC.
Randy Magee
