Split Plate Load Resistor SWitching
sliberty
Post by sliberty »
I was reading Paul Ruby's wonderful description of the split plate load resistor approach to lower output levels in an Express ( https://tubeamparchive.com/viewtopic.ph ... z&start=15 ), and wondered if it would work in a switchable arrangement. Here is the layout I came up with.
Is there any reason (like noise, etc.) not to move the resistors to a switch? Is there a better way?
Thanks,
Steve
Normster
Re: Split Plate Load Resistor SWitching
Post by Normster »
Not to talk you out of it, but I think it's easier to add a resistor to the board and relocate your B+. Then the switch is pretty simple, much like the Komet pics...
sliberty
Post by sliberty »
Yes, of course you are right - this is more elegant. I was trying to avoid making any changes to my turret board, mainly because I didn't make it myself. I bought it with turrets already installed, and have no spares :(
But, I have flea clips - Yea!!! So, I will simply use a single flea clip to enable me to place the 2nd resistor on the board as your diagram shows. And the switch will be much simpler as you stated.
Did you build this way? How were your results?
Thanks,
Steve
Normster
Post by Normster »
If you don't want to modify the board, you could drop the 100k to an 82k and put just the 22k on the switch.
I tried the split load using a 100k trimmer instead of the 82k/22k pair. I found that I prefer the breakup at a full 100k so I didn't bother with the mod.
I did however replace the 1M PI input resistor with a 1MA pot as a master volume. There's still nothing like power tube saturation but at least it's a decent practice volume when I need it.
Allynmey
Site Admin
Post by Allynmey »
Normster wrote:Not to talk you out of it, but I think it's easier to add a resistor to the board and relocate your B+. Then the switch is pretty simple, much like the Komet pics...
This is exactly the same as the Komet Fast/Gradual switch. :roll:
Allyn
Normster
Post by Normster »
Allyn
:wink:
roknroll
Post by roknroll »
Hi Guys
I think? you have the 22k and the 82k backwards? 22k goes to B+, 82k to plate and and throw. (ala Komet)
Regards
bluefireamps
Post by bluefireamps »
roknroll,
You're right. The 22K goes to B+, 82K to the plate.
Dave
Tube Powered
RockinLocken
Attack switch
Post by RockinLocken »
I have decided to rename this configuration, "Attack". Don't wan't the clone police to confiscate this thing. I followed a scheme someone was kind enough to shoot my way. It does show the 22k closer to the B+. Anyway's, thanks to all of you this thing is coming along and soon the whole neighborhood will be pissed not just my old lady.
Vince
Post by Vince »
Having B+ on switch isn't good idea - I use two 0,1uF caps instead one,
each cap go to switch.
regards.
V.
sliberty
Post by sliberty »
Interesting point. How does Komet do this?
tictac
Post by tictac »
I never believe it's a good idea to put high voltage DC in a mini toggle switch, I don't think it's a good safety practice. I like to do my switching after the coupling cap. But that's just me.
TT
sliberty
Post by sliberty »
I assume that using a full sized switch (which I did) is no safer???
rhinson
Post by rhinson »
the couple hundred volts dc on these toggle switches is no big deal. most of these halfway decent mini toggles are rated 6a/125v, the better ones can even be rated at 10a/125v. if you're scared of the metal bat handle, just put one of those colorful slipover covers on it. but the switches can handle the relatively low dc voltage and very low current just fine. rh
tictac
The Way I do it
Post by tictac »
Here's how I do my split load switching. Not only is it safer to switch after the caps, with this arrangment you can use the unused triode in V2 and really tune the gain and tone of the stage with the .1 cap[/img]
