2 watt Express build pix (added clips too!)
bancika
Post by bancika »
MCK
Re: 2 watt Express build pix (added clips too!)
Post by MCK »
Looks like a very clean build! Congratulations!
Cliff Schecht
Post by Cliff Schecht »
Are you the Bancika fro DIYSB? Nice looking build btw..
Cliff Schecht - Circuit P.I.
bancika
Post by bancika »
that's me :) thanks guys
Nice!
What is the enclosure?
bancika
Post by bancika »
I got it in a local electronic supply store. It's very nice because each panel is removable separately. Doesn't look as good as wooden box but for what I need is just right :)
Cheers
I like it.
I think it looks very utilitarian.
Do you know who makes it?
bancika
Post by bancika »
it's a local company here in Serbia, I doubt they are selling somewhere else :)
Great job on your build. :)
hairyandy
Post by hairyandy »
Looking good Bancika! Thanks again for the many years worth of use that I've gotten from your software. You rock!!!
Andy
Lale
Post by Lale »
Hi!
Great build!! Are you able to do some soundclips? Very keen on hearing your amp.
That bias adjustement circuit is very ingenious! Liking it a lot!
bancika
Post by bancika »
Finally got a chance to record few clips. All of them are recorded with my Ibanez RG2550 with hi output pickups (Dimarzio Crunch Lab and Liquifire), so these clips are crunchy. I'm yet to try it with my Strat for cleaner sounds. Amp is running into a 8.2ohm 9w resistor as a dummy load and Palmer PDI-09 speaker sim. Cool thing about that is that I can use time based FX and post EQ after the speaker sim. On one of the clips I'm using delay. Other than the Palmer, no EQ-ing is done. Noise level clip has the same riff played at various volume settings with a second or two before and after so you can get the picture of noise to signal ratio. Also, I left few secs of white noise at the beginning of part 2. IMO, it's pretty decent in that regard. Anyways, here are the links
http://www.youtube.com/watch?v=mc9dRt9lC50
http://www.youtube.com/watch?v=425oKrxu_Xc
http://www.youtube.com/watch?v=KLMjr2PfaNo
http://www.youtube.com/watch?v=QFS6cWCXuX8
Bane
Lale
Post by Lale »
Thanks a lot! Looking forward for those Strat/single coil clips!
bancika
Post by bancika »
Here's another clip to show how responsive the amp is. Amp volume is set around 50% and is not changed, I only played with guitar pickup selector switch and volume knob. Still haven't tried it with the Strat, should clean up even better.
http://www.youtube.com/watch?v=hw3QToxi67k
Bane
