funny voltages on my rocket
beasleybodyshop
Re: funny voltages on my rocket
Post by beasleybodyshop »
Reeltarded wrote:Creeping up..
Swap PI tube? Remove PI tube?
WAG.. Lift the inout to the PI at the PI, don't leave a wire hanging off it. (antenna) and that still wants to go China Syndrome? Just looking for runaway signal out of audible range, that's all. I am out of big ideas.
Pulled the phase inverter tube entirely. Still wants to creep up.
didit
Post by didit »
Grasping at what for me is the last straw --- disconnect the power bypass capacitor. Does no harm to remove but really unlikely it's causing a problem.
The only other thing I know of that might be pulling it up is super-hot screens. Earlier measurement suggest that's unlikely too.
Best ... Ian
Are you positive these tubes are good ?tried them in another amp
No voltage on pin 2 with the tubes out?
Really sounds like a couple of leaky tubes or bad coupling caps or some kinda crazy supersonic oscillation
beasleybodyshop
Put a tube rectifier in - voltages go down, cathode voltages seem to hover around the 9.6 mark. Still have a weak output. Here are my voltages for everything. Phase inverter is showing high voltages - what does this mean? Ive swapped in a few different PI tubes with the same approximate voltages.
Has to be wrong value resistors in that PI circuit. I've done that a few times myself.
Check all of the solder joints, grounding, and resistor values around the PI.
In your picture the plate resistors on the pi look wrong what do the measure
beasleybodyshop
cbass wrote:In your picture the plate resistors on the pi look wrong what do the measure
plate resistors are 100K
beasleybodyshop
All my resistor values in the PI match up - plates are 100K, shared cathode is 1.18K going into a 46.4K to ground. Grid resistors are both 1Meg.
Hmm the color codes don't look like it but if you measured them then they are.
Are you sure they aren't 100 ohm
Most likely the 1k2 PI bias resistor.
The 47k tail resistor is going to ground correct.
beasleybodyshop
cbass wrote:Are you sure they aren't 100 ohm
Hot damn. I should give you a cigar! They are 100ohm.
I told you so. :lol:
I refuse to let Cbass get the credit. :)
YOU DICK!!
lmao not you Mark... :)
