Now, not all amps have the same layout. The BF Twin, for example, finds its resistive load on channel 1 way down the road from the coupling cap after stage 2 - and it seems pretty quiet relative. But then it is not high gain. This is the problem. In terms of amplitude, that EXP bright switch cap is a hot potatoe realtive to anything found on a BF amp. But note the signal chain: cap>resistor. In fact, if you could shorten up the signal path, placing that BF coupling cap right next to the 220K resistor before the PI signal cap, the BF would be quieter. It has to be because we removed 12" of antena wire. But then, in this low gain amp, the other components make even more noise and you would never realize that you had improved something. Again. not so with the EXP.
 OK?
