Liverpool bass reduction?
Ledvedder5150
Re: Liverpool bass reduction?
Post by Ledvedder5150 »
Littlewyan wrote: Wed Feb 08, 2023 11:14 pm What if you clip another 2.2nF in parallel with the existing 2.2nF between the 2nd and 3rd stages? Interested to see if you get closer to Pete's sound or if you feel the bass situation becomes much worse.
Wouldn't that increase the bass response?
Check out my band: https://www.facebook.com/ungluedband
Ledvedder5150
Just tried another 2n2 in parallel. As I expected, the bass response increased.
It might be the curve on your output tubes.
Once you get to the gain knee, the tone stack looks like nothing to an el84. It translates all input to be more coal, that's all.
Wooo! Wooo! Chugga-Chugga.
Here is a thought (and I am with you on circuit deviations so let's talk from a perspective of we agree on Chante being the baseline)
The Liverpool has too much gain to be a multi-voice amp. It flattens the output. Bulldozer. Parking lot. Billard table.
If you like that one sound you are stuck with one option. Throw tubes at it until it does one good thing.
This is my opinion.
Ledvedder5150
Considering what adding a 2n2 in parallel did to the tone, I may try reducing that cap to 1nF. I'll report my findings when I get a chance to make that change.
Littlewyan
Post by Littlewyan »
I thought you may have been losing too much of the lower mids with all the bass cutting you were doing, that's why I asked you to put another 2.2nF in parallel, to see if it got you closer to the sound Pete was getting.
Have you got any gut shots of the amp you can share by the way?
Ledvedder5150
Here are some pictures.
Colossal
Post by Colossal »
Ledvedder,
The cathode bypass cap on your output tubes is only 25uF. It is normally 220uF (250uF is ok too). Did you intend to do that? Very nice build though.
Ledvedder5150
Colossal wrote: Fri Feb 10, 2023 12:21 am Ledvedder,
That's what was shown in the layout I followed. What would be the difference with a 220uF?
Roe
Post by Roe »
try 2n2 or 3n3 cathode bypass caps on the two first gainstages
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Ledvedder5150
Roe wrote: Fri Feb 10, 2023 9:50 am try 2n2 or 3n3 cathode bypass caps on the two first gainstages
In place of the 22uF caps?
Roe
Post by Roe »
Ledvedder5150 wrote: Fri Feb 10, 2023 2:00 pm
yes
4x12" w/H75s
