rooster wrote:Alright, let me get my facts straight.
Andy - In your scope pics, you are showing an Express circuit using EL84s?
Oh for a straight answer....
There is a schematic in that AX84 post, I think:
It started as a 'standard' 4-4-0 which is an Express preamp with a low er gain 12AY7 PI driving a 6SN7 dual triode fixed bias at ~2W (with some changes to NFB loop & PI resistors).
I added cathode biased EL84s to the same PI (with appropriate OT tap changes & NFB loop components.
The early scope pics on AX84 (with the big negative peaks on the PI output) reflect this cofiguration - EL84 or 6SN7 as per the note in the pics.
I didn't like it, so changed back to an Express PI, and used split load anode resistors to scale the PI output down to suit the EL84/6SN7 drive requirements (which are very similar). The later scope shots relate to this configuration. From memory, the output from the split load resistors is 40% of the full 'Express' output. I chose this to reflect the ~12v bias point of the 6SN7 and EL84 vs the ~30V of EL34s.
(As an aside, I don't think the EL84s were a good idea).
What I think is happening:
1) I don't belive the output is lower 'mean' than 'clean'. I haven't see this on the scope.
2)The output of the PI is proportional to the difference between the signal coming in and the signal coming back through the NFB loop. (If we don't agree on this, you may as well stop reading now!
3) Up until the output valves are driven to grid conduction, the output is clean & symmetrical - "clean".
4) Once there *starts* to be grid conduction in the power valves (by a fractional increase in the amplitude of the signal coming in) the NFB loop becomes unstable, as follows:
I'm working 1 signal waveform cycle at a time here, holding the input constant:
Because the output has clipped slightly, the NFB signal back to the PI is less than is should be through this part of the waveform, so the *difference* between the NFB signal and the signal coming in is greater than before clipping - so the PI output gets greater through this part of the cycle (in keeping with 2 above). Because the NFB is 180 degrees out of phase, the extra PI output caused by clipping on the +ve part of one PI output appears on the bottom of the opposite side of the PI - these are the 'nipples' (I can think of no better description, sorry!) that appear on the bottom of the PI output.
I think that much is standard.
The output of the PI is AC coupled to the power valves, so when the input signal moves on 180 degrees, the power valve grid doesn't 'see' a large negative excursion with a standard sized positive signal on top, they see a signal equally balanced about their bias point, so the added signal on the negative half of the PI output looks to the power valve like the whole PI signal has increased in amplitude (with the bottom half distorted).
As we were on the verge of clipping on the last cycle, and now have what appears to be a bigger signal, there will be more clipping on the next cycle, so a bigger difference between the signal in and the NFB signal, a bigger nipple on the -ve side of the PI output, so what appears to the power valves to be an even bigger signal, even more clipping, etc. etc.
This will continue until the PI runs out of available voltage swing, where the system becomes stable again, as the drive to the power valves becomes limited by the available voltage swing from the PI.
The nub:
Within a few cycles of the signal, the magnitude of the PI output has been increased from 'barely clipping' at the power valves until it has used up all the available PI headroom. All this *at a constant input signal*, at a level *just* sufficient to cause the onset of grid conduction in the power valves. - We are now "mean" !
I don't know how sim software would handle this unstable condition.
Any increase in the input signal will have only a small effect, driving the PI output a little further into compression.
5) I have my doubts about ever getting enough signal to cause grid conduction in the PI, but well before this, the input signal alone would be sufficient to drive the PI into distotion. Once this happens, the NFB has no effect - it's the 'window' between grid conduction in the power valves and saturation of the PI due to input signal alone that I'm working in.
This is just my best shot at explaining my take on it - Other opinions are tolerated
If somebody wanted to verify this (or otherwise), they could see if disconnecting the NFB changed the clean-mean behavior. It does on my amp, but it's not an Express. It's close enough that I'm happy with writing all this, though.
As ever: YMMV.
Andy
