Well technically you measure the Volts DC on the drop across the ground resistor, and get mV at about 6.5, Assuming the 1 ohm resistor with ohms law means 6.5mV = 6.5mA yes, do not put your meter in amps measurement, you need to use that a completely different way and it's more dangerous. Just make sure you're measuring the voltage drop not amps directly.mehfuzhoss wrote: ↑Thu Sep 12, 2019 4:25 am Okay. So i will put my red and blk probe and trim it untill
It reads 6.5 ma on the meter and repeat the same for the other trim pot
Am i right?
The idea you've stated is right, get each to about the exact same current.
~Phil
