Matt thanks for the reply, but I'm not too sure what you are trying to tell me, I'll try and break it down.
In short- bias resistors/bias voltage/static current don't exist in a nutshell. Supply voltage (and increase of sag through choke for plate supply or not counteracted by size of filter caps and/or induced voltages through choke) all create effects downstream of what the OT is doing. It's not quite fair to say "good enough for brian may!", it ends up being an apples/oranges comparison. (at least oranges/grapefruit, not even tangerines).
As far as the choke goes, I've heard Mark Huss say how he likes this circuit. I wouldn't think of a choke as a source of sag, if sag were to occur the choke will try and provide some regulation with the energy stored in it.
I suppose more importantly I don't know what that has to do with changing the 100 ohm screen resistors to 270 ohms?
This also requires dinking with the drive voltage to compensate if the bias voltage is changed. If the screen voltage is also dinked, you're also dealing with new curves.
I don't understand why I'd need to change the drive voltage to compensate for the bias. I agree the rail will increase with a higher cathode resistor, but the differences in voltages aren't all that great, I've updated the Excel spreadsheet to show the differences in voltage and current.
I don't know about the class A thing, I just haven't looked into it. Agreed the operating point of the valve will be the chief factor and the Z primary will be a part of that.
