a twreck build started - questions
Guitar Adjuster
Re: a twreck build started - questions
Post by Guitar Adjuster »
Is there a difference between 22u and 25u that you can hear?
Allynmey
Site Admin
Post by Allynmey »
I Don't think so....but hey, who knows. :?
rockstah
Post by rockstah »
there is a difference. if u could hear it is another story. but again if yer trying to build to spec u use what is spec. ;)
UR12
Post by UR12 »
Most of these caps have a +/- 10% tolerance so the 22uf can be anywhere from 19.8 - 24.2 . Same thing with the 25uf, 22.8 - 27.2
It should be interesting to see if you can her any difference. Depending on the values, you could end up with the same value cap no matter which one you use
rockstah
Post by rockstah »
UR12 wrote:Most of these caps have a +/- 10% tolerance so the 22uf can be anywhere from 19.8 - 24.2 . Same thing with the 25uf, 22.8 - 27.2
absolutely!
i want the 22u caps for the cathodes to make my build look the part. ;)
