DIY AIR BRAKE WITHOUT THE RHEOSTAT?
Re: DIY AIR BRAKE WITHOUT THE RHEOSTAT?
layout as well please jesse.mancillas@gmail.com
I added a thread to the Trainwreck files section that includes what I have regarding layouts and schematics. Hope this helps.
https://tubeamparchive.com/viewtopic.php?p=87356#87356
Schematic for rheostatless updated airbrake
Hey Ross can I get the schematic and or layout for the rheostatless updated airbrake.
Thanks in advance...
johnruppe@gmail.com
johnruppe@gmail.com
Hello to all of you, TW addicted
It's my first post here, on this very interesting forum, and helpfull of course. I own Ceriatone TW express, my new beast.
I'll build Airbrake rheostat less version.
Would someone, pls, post a Mouser code for that 25W 8 ohm resistor.
Thanks in advance in regards
"Would someone, pls, post a Mouser code for that 25W 8 ohm resistor"
284-HS25-8.0F
284-HS25-8.0F
So on the layout in the above linked thread, if one were to want variable load impedances, could a selection of of 25W resistors be used and switched (4 ohm, 8 ohm, 16 ohm, etc.)?
Exact science is not an exact science
Not sure if anyone's spotted this in the press recently, but it appears that Dr Z has taken up the mantle...
http://www.drzamps.com/brakelite.html
Betcha it still costs a bomb though
R.
R.
www.rossedwards.net
Carlsbro 50 Top (modded), Blackstar HT-5 & PRS Custom 22
Dr Z has had the brake light for a while now and the pricing is
$169 or $149 when preinstalled in a combo amp.
jcruppe wrote:"Would someone, pls, post a Mouser code for that 25W 8 ohm resistor"
284-HS25-8.0F
Thank you very much!
Sorry people if I disturb discussion...
I'd like to order Airbrake parts BOM for rheostat less (to Mouser), but estimated leadtime for adjustable resistor 25ohm/100W is 8-10 weeks.
I'm from EU, did/do you experience the same leadtime in USA?
Any sugestion or info appreciated.
Did anyone find European supplier maybe?
regards
regards
Digikey seems to have them in stock:reverbus wrote:Sorry people if I disturb discussion...
regards
http://search.digikey.com/scripts/DkSea ... 00J25RE-ND
rawnster, it helps a lot
, thanks!
That Lorlin switch is only rated 150 mA. Isn't that a problem?
