Airbrake schematic or layout
Re: Airbrake schematic or layout
Man, we need to get this diagram posted somewhere so that this silly dance can finally end.
- LeftyStrat
Here's a thread on Music Electronics forum that has all the info:
http://music-electronics-forum.com/show ... php?t=4339
Hopefully Omar this is okay, since I'm just linking to a another forum, rather than posting the actual info here. If not feel free to delete this post.
Please Help Schematics Needed
Hello,
can someone please send me schematics of the airbrake design please. I searched troughtout the entire forum could not find it, did not want to ask or bother any one but I see no other way. Thank you very much
My email: ledz4aiden@gmail.com
Dmitri
- johnny riff
hello could I please get a copy of the schematic as well. thanks john
- LeftyStrat
If you click on any of the links in this thread, your questions will be answered grasshopper.
- JIMI HAIRLESS
airbrake schematic
Could I bother you for that schematic too please?Icetech wrote:will email it to ya
airbrake schematic
Could I get a copy too please? Thanks
- JIMI HAIRLESS
AIRBRAKE WITH 100 WATT PLEXI
Ken Fisher himself said it was perfectly safe to use with a 100 watter! The airbrake manual confirms this and suggests mismatching the load with a vintage amp:rockstah wrote:in other words its safe for my 100w plexi to use this airbrake?
"When using the Airbrake with older vintage amps, mismatching the load will be a safer way to operate. This will eliminate any overheating of the output transformer. For example, a Vox AC30 or vintage 100 watt Marshall should be run at 8 ohms through the Z Airbrake with a 16 ohm speaker load."
- JIMI HAIRLESS
Resistive attenuator
Maybe it's ok to do this now. If not, I'll retract it.
Great things happen in a vacuum
- JIMI HAIRLESS
PREVIOUSLY POSTED AIRBRAKE SCHEMATIC
I see 3 resistors in the previously posted diagram?? The above layout however is right on the money!HiGain wrote:So, does this look correct?
Jason G aka Jimi Hairless
"...this one goes to eleven."
I'd like a copy of the schem. kreepz@hot.ee
Re: Resistive attenuator
Nicely done!bnwitt wrote:Maybe it's ok to do this now. If not, I'll retract it.
Ken
Real guitars are for old people! - Cartman
I thought it'd be interesting to price out the parts based on the above diagram:
1. $9.83 Mouser# 588-L100J25RE: 100 Watt/25 ohm: Ohmite 270 Series
2. $17.42 Mouser# 588-D100K-25: 100 Watt/25 ohm: Ohmite 210 Series
3. $31.38 Mouser# 588-RJS150E: Ohmite Power: Rheostat: 50Watts: 150 ohms
4. $4.76 Mouser# 10WA365: Lorlin Rotary Switch: 2 pole: 6 position
5. $2.24 Mouser# 588-12-E: Resistor Mounting: brackets 4 needed
6. $3.28 Mouser# 588-2125E 2 extra lugs
7. $13.23 Mouser# 546-1444-14: 5" X 9" X 2": Hammond spot welded aluminum Chassis
8. $5.09 Mouser# 546-1434-14: 5" X 9": Hammond aluminum chassis cover
9. $1.63 Mouser# 75-715P400V0.1: Capacitors 400volts .10uF 5% ORANGE DROP
Total: $88.86
That's a doable price....compared to spending 3x cash on certain "name brand" products.
Total: $88.86
