Amp Viagra?
Winder
Amp Viagra?
Post by Winder »
I love my Express build. Closest thing to the tone in my head I've had, and I haven't flipped the switch on any of the herd of "other" amps currently taking up space in my music room. But ...
I recently decided to mod a Boss GE-7 as I love the pedal but it hisses a lot out of the box and I heard it could sound better with different Op Amps. My original GE-7 sounds good. I bought a new one just to mod and put it in front of the Express. Set it relatively flat (frown, with boost but fairly flat across 200Hz to 3.2kHz). Now we're talking. I know this tone isn't everyone's cup-o-tea, but it's nirvana for me except for a bit of hiss (less than pre-mod), which I can generally live with.
I know I'm guilty? ... of thinking I should be able to get exactly what I want by jacking straight in, but damn, I've been after this shizz for 40+ years. I only wish I didn't have tinnitus so bad now so I could rip it up a bit louder. It's exhilirating to be able to play for an hour or more without even thinking "Man, this is great, but there's just a little sumpin'-sumpin' that seems to be missing." When you're mind is on what's missing, the groove is missing too.
So, is this something I should be able to "tweak" into the amp without the EQ on the front or should I just go with the EQ and call it a day?
Colossal
Re: Amp Viagra?
Post by Colossal »
Good for you, man! It's always great when you find your tone, you know?
lumox0013
Re: Amp Viagra?
Post by lumox0013 »
im gonna go with ( if it aint broke - ?() nothing wrong with a little pedal love. ! cheers
Live , Love , Learn
Roe
Re: Amp Viagra?
Post by Roe »
Winder wrote: Tue Jun 25, 2019 1:59 am I love my Express build. Closest thing to the tone in my head I've had, and I haven't flipped the switch on any of the herd of "other" amps currently taking up space in my music room. But ...
Modding the amp would be interesting. I'm removing some low bass on mine, using a 2.2uf cathode cap on the two first stages
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Winder
Re: Amp Viagra?
Post by Winder »
Don't do that to me Roe!! :lol:
I do like a bit "crisper" bottom that cuts through the mix a bit more. Let the Bass guitar provide the predominance of bass, if you will. Not thin, but a bit of edge that I couldn't seem to just dial in with the amp EQ without getting ice-picky. I'm pretty confident that my pickups are on point. I installed a Monte Allums GE-7 Plus mod ... cap upgrades, chip sockets, replaced the original Op Amps with RC4559P and OPA2134PA Op Amps. Really enhanced the clarity and harmonics and dropped the noise quite a bit. Can "roll" Op Amps now too, I guess. Probably can't run it on battery very long due to higher current draw, but I use a power brick so I thought I'd give it a run.
I have most of the parts gathered for another Express and a Rocket ... just need the iron, and to get going.
Roe
Re: Amp Viagra?
Post by Roe »
instead of the ge7, try a 2-5nf bright cap. it gives a great boost with tight lows. add a small snubber if there's too much treble. I'm using a 470pf cap between grid and cathode of the first gainstage, simulating a high capacitance guitar cable (common back in the day). the added capacitance changes the resonanse peak freq of the pickups downwards from ca 5k to 2k (dep. on capacitance obviously)
4x12" w/H75s
